Cannot Ping RIP Routed IP
coolboarderguy
Hi All,
I have 3 routers within Boson Sim. PIR1, PIR2 and PIR3. Serial 0/0 on PIR1 has an IP 195.10.1.2/30 and PIR2 serial 0/0 195.10.1.3/30. PIR2 also has an IP 195.10.1.5/25 on the fastethernet 0/0 and PIR3 has an IP 195.10.1.6/25. All have been configured for RIP ver2. I added network 195.10.1.0 on all 3. The only connection that won't ping is between PIR1 and PIR2. What have I missed? Cheers.
coolboarderguy
Th ip add scheme you were using were overlapping each other.If your using /25 then the range is from 195.10.1.0-195.10.1.127. So, the other serial wont take the same interface.
Plan your ip add acheme in follg way:-
PIR1-195.10.1.129/30
PIR2-195.10.1.130/30
PIR2-195.10.1.1/25
PIR3-195.10.1.2/25
HTH.
Cheers,
Nikhil E.
9 Replies 9
Edison Ortiz
195.10.1.3/30 is the broadcast address for subnet 195.10.1.0/30.
The allowed host addresses for that subnet are 195.10.1.1/30 and 195.10.1.2/30
DOH!! Ok, when setting serial 0/0 on PIR2 to 195.10.1.2/30 it says it overlaps with fastethernet 0/0 195.10.1.0. Cheers.
coolboarderguy
Hi All,
obviously I'm doing something fundamentally wrong here? Cheers.
Gateway of last resort is not set
195.10.1.0/25 is subnetted, 1 subnets
C 195.10.1.0 is directly connected, FastEthernet0/0
coolboarerguy
Yes something is fundamentally wrong here. A basic concept of IP addressing and subnetting is that the same subnet should not exist in more than 1 place in the network. But you have taken the same /24 (class C) network and created serial link (/30) subnets and LAN (/25) subnets.
"PIR2 also has an IP 195.10.1.5/25 on the fastethernet 0/0 and PIR3 has an IP 195.10.1.6/25"
This puts the same /25 subnet on 2 different routers and the LAN subnet is using the same address space as the serial links.
My suggestion is to start over and plan a more effective addressing scheme.
Rick
Rick
PIR2-195.10.1.1/25
PIR3-195.10.1.2/25
HTH.
Cheers,
Nikhil E.
Hi All,
ok, what's being said here, is, you can define larger subnet ranges and then break it down into smaller ones, IP/25 and then IP/30, but not IP/30 and then IP/25, yes? Cheers.
coolboardeguy
Yes your absolutely right. Always go from high to low i.e. high no of users to low.This the best practice.
HTH.
Cheers,
Nikhil
Nikhil
There is a serious problem in your suggestion. You suggest this:
PIR2-195.10.1.1/25
PIR3-195.10.1.2/25
but this means that the same subnet will exist in 2 different places. Both of those addresses describe a subnet which starts at 195.10.1.1 and goes through 195.10.1.127. It is a problem if you try to put the same subnet on 2 different routers. If you want at least 2 LAN subnets and some serial subnets to all come out of a /24 (class C) address space then the LAN subnets can not be larger than /26 (instead of /25). With /25 there are only 2 subnets in the address space. With /26 you can have 4 subnets.
Rick
Rick
Rick,
I think u hv taken me in wrong way.I'll elaborate it for you.
PIR1-195.10.1.0/25-PIR2-195.10.1.128/30-PIR3
Cheers,
Nikhil E.
