Cannot Redistribute BGP into EIGRP
mnlatif
Level 3
Level 3
Trying to re-distribute BGP into EIGRP with no luck.
router eigrp 2
redistribute bgp 64520 metric 3000 1 1 1 1
network 10.63.253.0 0.0.0.255
no auto-summary
router bgp 64520
no synchronization
bgp log-neighbor-changes
neighbor 10.3.254.33 remote-as 64520
no auto-summary
sfsl-router-vpn#show ip bgp
BGP table version is 5, local router ID is 10.63.253.3
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
*>i10.3.0.0/16 10.3.254.33 30720 100 0 i
show ip route bgp
10.0.0.0/8 is variably subnetted, 8 subnets, 5 masks
B 10.3.0.0/16 [200/30720] via 10.3.254.33, 00:28:27
sfsl-router-vpn#show ip eigrp topology
IP-EIGRP Topology Table for AS(2)/ID(10.63.253.3)
Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
r - reply Status, s - sia Status
P 10.63.253.134/32, 1 successors, FD is 297372416
via 10.63.253.126 (297372416/128256), Tunnel3
P 10.63.253.0/25, 1 successors, FD is 297244416
via Connected, Tunnel3
Am i missing something here ?
Richard Burts
Muhammad
What you are missing is that by default routes learned by IBGP do not redistribute into an Interior routing protocol like EIGRP. So this is the cause of your problem.
You can use the command bgp redistribute-internal under the bgp process to change this behavior. It should allow the redistribution of the BGP routes into EIGRP.
Rick
Rick
Richard Burts
Muhammad
Rick
Rick
Muhammad
I am glad that my answer was helpful. Thank you for using the rating system to indicate that your issue was resolved (and thanks for the rating). It makes the forum more useful when people can read about an issue and can know that they will read a response which did resolve the issue.
The forum is an excellent place to learn about Cisco networking. I encourage you to continue your participation in the forum.
Rick
Rick
