Running a 7200 with IPX enabled over ATM link. All worked fine but all of a sudden I cannot see the IPX networks across the WAN link. The local IPX network is working fine and the IP networks appear to be fine. Any thoughts?
When you configure the Cisco IOS software to transport IPX packets over a serial interface that is running a WAN protocol such as X.25 or PPP, you specify how the packet will be encapsulated for transport. This encapsulation is not the same as the encapsulation used on an IPX LAN interface.
The following URL illustrates IPX over a WAN interface.
http://www.cisco.com/en/US/docs/ios/12_0/np2/configuration/guide/2cipx.html#wp8338
