05-14-2015 08:32 AM - edited 03-05-2019 01:28 AM
Hi all,
i have the following config on the 3560:
interface GigabitEthernet0/44
no switchport
ip vrf forwarding management
ip address 10.77.195.2 255.255.255.128
end
no switchport
no ip address
end
Interface Gi0/4 is connected to a 3945 on interface Gi0/3 with the following interface
interface GigabitEthernet0/3
ip address 10.77.195.11 255.255.255.128
duplex auto
speed auto
end
why cant i ping from 3560 - 10.77.195.2 to 10.77.195.11 on the Cisco 3945?
Solved! Go to Solution.
05-14-2015 01:17 PM
This won't work.
A L3 routed port on a switch terminates the IP subnet so nothing can go past it ie. you cannot come in to the switch on a different port and then go to the L3 routed port in the same IP subnet.
You have three options -
1) make gi0/4 the L3 port and assign the IP to that port
2) connect the switch to the router using gi0/44 instead
3) if you want to keep connectivity as it is then use a vlan and SVI ie.
assign gi0/4 into a vlan, create a L3 vlan interface (SVI) for that vlan and assign the IP address on gi0/44 to the SVI instead.
Jon
05-14-2015 08:41 AM
your in the management vrf you would need to set the ping like ------- ping vrf management 10.77.195.11 or else remove the ip vrf forwarding from the interfaces
05-14-2015 09:06 AM
hasnt made a difference.
i took off the vrf config on port gi0/44 but still cant ping .11
05-14-2015 09:20 AM
You would need to take it off both interfaces , can you post the show ip IInterface for each interface , are these directly connected to each other by these ports
05-15-2015 01:37 AM
MarkMalone2008
taking the vrf off the 3945 would not have made a difference.
Anyways i followed advice of Jon Marshall above and made the interfaces on gi0/4 and gi0/44 access vlan ports and moved the .2 config to a SVI.
i can now ping across the switch and communicate with the 3945.
many thanks all
05-14-2015 01:17 PM
This won't work.
Jon
