Cant Ping
tmertes
I am a student and I am having difficulty understanding how to get my devices to ping each other. I have assigned the designated IP addresses to the devices and am at a loss. I have reached out to my teacher but it has been unsuccessful in aiding my issue. How do I troubleshoot? I have redone this project now 3 times following the instructions and got the same result each time.
NetworkDave
@tmertes,
Welcome to the community!
Please provide any instructions you were given.
Here is the solution for the Remote-Office-1 segment of your network:
Pings fail - Manufacturing-PC1 from/to Manufacturing-PC2
Change Manufacturing-PC1 static IP address of 192.16.30.100 to 192.168.30.100
The Default Gateway of 192.16.30.1 needs to be changed to 192.168.30.1
Manufacturing-PC2 has a static IP address of 192.168.30.101
The Default Gateway of 192.168.30.2 needs to be changed to 192.168.30.1
Pings successful - Manufacturing-PC1 from/to Manufacturing-PC2
Let the community know if you still need help and we'll assist you.
Remember to mark helpful posts and mark the correct answer as a solution; It helps other users with similar questions.
Hello
your remote office hosts had incorrect ip addressing and also the main rtr routed interfaces required vlan tagging to the correct vlan (sub-interfaces)
Please see attached working PT file.
Kind Regards
Paul
