Cat3750 copy run start error
Cisco Tech
I have a 3750 stack of 4 switches that was installed about 2 years ago. Recently I was doing some work on the switch and realized that I am unable to save the config. I amobviously concerned that if the power fails or the switch reboots I will be reconfiguring it and that is not something I am interested in doing! Any help would be appreciated.
Here is the error that I am receiving:
switch#copy run startup-config
Destination filename [startup-config]?
Building configuration...
nv_done: unable to open "flash:/config.text.new"
nv_done: unable to open "flash:/private-config.text.new"
nv_done: unable to open "flash:/multiple-fs.new"[OK]
0 bytes copied in 5.730 secs (0 bytes/sec)
~BRAD
Ivan Shirshin
I think you made a duplicate post. I have replied to you in other thread:
https://supportforums.cisco.com/message/3675873#3675873
Kind Regards,
Ivan
**Please grade this post if you find it useful.
Kind Regards,
Ivan
Ivan Shirshin
Kind Regards,
Ivan
Kind Regards,
Ivan
Thank you Ivan. I must have accidentally entered it twice!
~BRAD
Duplicate posts #3.
I'm having this same issue but the link you provided is no longer valid... can anyone point me to a new discussion where this is answered?
