Catalyst 1900 question
tgathright
Level 4
Level 4
I'm studying for my CCNA. The WestNetLearning study materials I have indicate that I should be using a CLI to establish the ip & default gateway, but my Catalyst 1900 goes straght to a menu (instead of the cli I was expecting). Even my router simulation software places me into a menu w/o the ability to get to the CLI. What have I missed?
pkhatri
Level 11
Level 11
The Cat1900 allows you to access the CLI from the menu. Simply hit "K" and you will be taken to the CLI.
Hope that helps - pls do rate the post if it does.
Paresh
ststaley40
When it starts up, say no to entering set up mode and then you can go to CLI from there.
