ā09-28-2013 10:20 PM - edited ā03-04-2019 09:10 PM
I have problem in Catalyst 2900 switch every 2days it's stop working and only sys led ON stable, also all switch port led went off no connectivity between core switch.i have to do manually power off and power on again to make it working.Any help on this problem would be greatly appreciated!
ā09-28-2013 11:17 PM
Since you reloaded the switch then there is no logs we can get from it, i believe you should try loading a different ios and monitor, if the issue persists then replace it,
ā09-28-2013 11:25 PM
can you help me to upgrade to new version because i never did upgrade before. it running currently this version
Cisco IOS Software, C2960 Software (C2960-LANBASE-M), Version 12.2(35)SE5, RELEA
SE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 19-Jul-07 20:06 by nachen
Image text-base: 0x00003000, data-base: 0x00D40000
Switch uptime is 0 weeks, 0 days, 1 hours, 33 minutes
System image file is "flash:c2960-lanbase-mz.122-35.SE5/c2960-lanbase-mz.122-35.
SE5.bin"
ā09-29-2013 12:25 AM
I' recommend to use version 12.2(55)SE8.
You can find the instructions how to update in the relaese-notes:
Rolf
ā09-29-2013 02:09 AM
2960 running only on Layer 2 (no default routing), 15.0(2)SE4 is also good.
12.2(55)SE8 would also be an alternative but I too would recommend.
ā09-29-2013 02:18 AM
Good to know, thanks Leo!
