Catalyst 2960 plus / ISE
hans.velez
Hi all,
Reading some data sheets and config guides there said that the only feature that ISE can support in 2960 plus is trustsec, is that rigth? There is any othe feature that can work with ISE and 2960 plus?
Jeffrey Jones
Level 5
Level 5
so appears all things are supported, however authentication for multi-auth is not configured
