catalyst 3550 ACLs
mustafa.s.raza
The customer is using fourscout security software to authenticate and separate manufacturing and corporate environment.
The catalyst 3750 supports 3000-3500 acl entries.
Currently each host requires an acl entry which will out last ACL limit on 3750 switch. Basically 4000 host/ entries are required.
Since this is more of a design issue , the client is open for recommendations.
One Idea is to create Vlans for x amount of host and have them match ACL or AD authentication and not to worry about mapping each host with individual ACL
What would you recommend? The client will not changes catalyst 3750 switches .
How can we design so that we stay within 3750 ACL list and supports not only 4000 users but also thousands more.
Any help will be greatly appreciated.
paolo bevilacqua
Wrong forum, post in switching. You can move yout posting using the actions panel on the right.
