Catalyst 3750X stack
Maurice Ball
Level 3
Level 3
I have bad flash memory in my Catalyst 3750X and it is stack with another Catalyst 3750G. I was sent a replacement switch. My question is when I replace the 3750X with the new switch, will I have to reconfigure the new switch in the stack, or will it get the current stack configuration from the 3750G.
mahmoodmkl
Level 7
Level 7
if it identical to the switch which failed thn it will get config or else u need configure it again
mahmoodmkl
Level 7
Level 7
thanks again, I really appreciate the help
