Highlighted
Beginner
Catalyst 3850 QoS police
Here is the config for Catalyst 3560 found under the link below.
I would like to do same setting on Catalyst 3850.
http://itknowledgeexchange.techtarget.com/network-engineering-journey/how-to-configure-per-vlan-qos-in-cisco-3550-and-3560/
mls qos
interface fa0/2
mls qos vlan-based
class-map INT
match input-interface fa0/2
policy-map NESTED_POLICE
class INT
policy 12800 1600 exceed-action drop
class-map HTTP
match protocol http
policy-map PARENT_MARK
class HTTP
set dscp af11
service-policy NESTED_POLICE
interface vlan 10
service-policy input PARENT_MARK
But commands like "mls qos", "mls qos vlan-based" and "match input-interface " doesn't work on 3850.
There is no helpful Cisco manual for it.
Could anyone help me?
Thanks in advance,
Taro
6 REPLIES 6
Highlighted
VIP Mentor
Hello
What ios are you using and sdm template
sh ver
sh sdm prefer
res
Paul
kind regards
Paul
Please rate and mark posts accordingly if you have found any of the information provided useful.
It will hopefully assist others with similar issues in the future
Highlighted
Hello Paul,
Thank you for the attention.
Here is the information.
#sh ver
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.02.01.SE RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Wed 20-Mar-13 17:10 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2013 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: C3850 Boot Loader (C3850-HBOOT-M) Version 1.1, RELEASE SOFTWARE (P)
SW01 uptime is 21 weeks, 6 days, 14 hours, 27 minutes
Uptime for this control processor is 21 weeks, 6 days, 14 hours, 30 minutes
System returned to ROM by reload at 22:27:58 JST Wed Jan 8 2014
System restarted at 22:27:52 JST Wed Jan 8 2014
System image file is "flash:packages.conf"
Last reload reason: Reload command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: Ipservices
License Type: Permanent
Next reload license Level: Ipservices
cisco WS-C3850-24T (MIPS) processor with 4194304K bytes of physical memory.
Processor board ID FOC1717V01B
24 Virtual Ethernet interfaces
56 Gigabit Ethernet interfaces
8 Ten Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
250456K bytes of Crash Files at crashinfo:.
250456K bytes of Crash Files at crashinfo-2:.
1609272K bytes of Flash at flash:.
1609272K bytes of Flash at flash-2:.
0K bytes of Dummy USB Flash at usbflash0:.
0K bytes of Dummy USB Flash at usbflash0-2:.
0K bytes of  at webui:.
Base Ethernet MAC Address          : 44:ad:d9:6d:4e:00
Motherboard Assembly Number        : 73-12238-06
Motherboard Serial Number          : FOC17163HB8
Model Revision Number              : B0
Motherboard Revision Number        : D0
Model Number                       : WS-C3850-24T
System Serial Number               : FOC1717V01B
Switch Ports Model              SW Version        SW Image              Mode
     1 32    WS-C3850-24T       03.02.01.SE       cat3k_caa-universalk9 INSTALL
     2 32    WS-C3850-24T       03.02.01.SE       cat3k_caa-universalk9 INSTALL
Switch 02
Switch uptime                      : 21 weeks, 6 days, 14 hours, 31 minutes
Base Ethernet MAC Address          : 20:bb:c0:01:86:80
Motherboard Serial Number          : FOC17163HCM
System Serial Number               : FOC1717V01K
Configuration register is 0x102
SW01#sh sdm prefer
Showing SDM Template Info
This is the Advanced template.
  Number of VLANs:                                 4094
  Unicast MAC addresses:                           32768
  Overflow Unicast MAC addresses:                  512
  IGMP and Multicast groups:                       8192
  Overflow IGMP and Multicast groups:              512
  Directly connected routes:                       32768
  Indirect routes:                                 8192
  Security Access Control Entries:                 3072
  QoS Access Control Entries:                      2816
  Policy Based Routing ACEs:                       1024
  Netflow ACEs:                                    1024
  Input Microflow policer ACEs:                    256
  Output Microflow policer ACEs:                   256
  Flow SPAN ACEs:                                  256
  Tunnels:                                         256
  Control Plane Entries:                           512
  Input Netflow flows:                             8192
  Output Netflow flows:                            16384
These numbers are typical for L2 and IPv4 features.
Some features such as IPv6, use up double the entry size;
so only half as many entries can be created.
Highlighted
Taro,
Check this link for info on QoS for the 3850:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/3se/qos/configuration_guide/b_qos_3se_3850_cg/b_qos_3se_3850_cg_chapter_011.html
The 3650 and 3850 implement QoS with MQC now.
Highlighted
Any idea?
Highlighted
Beginner
Can anyone help me?
Highlighted
Contributor
here is a generic example:
access-list 101 permit ip 192.168.1.0 0.0.0.255 host 172.16.10.2
class-map LIMIT_ACCESS
match access-group 101
policy-map LIMIT_2_MB
class LIMIT_ACCESS
police 2000000 conform-action transmit exceed-action drop
Apply this a an output policy to the relevant interface:
service-policy output LIMIT_2_MB
