Catalyst 4500 E-Series Supervisor Engine 7L-E
clark-white
folks,
I have a strange issue with 4500 E chassis loaded with SUP 7L-E which always remains in ORANGE LED status, also the uplink ports interface is down and the line protocol is down  but when i execute the command sh int gig1/5 it show me the media type sfp but there is no red laser light seen in the sfp transiever,
The below command is configured for the uplink gig port on the SUP engine.
hw-module uplink select gigabitethernet
10 Replies 10
Leo Laohoo
Can you please post the output to the following command:
sh interface Gi 1/5
sh log
sh run interface Gi 1/5
cisco_lad2004
Level 5
Level 5
Last time I has similar issues on this platform, it was IOS related.
Samir
Here is the below output.
interface GigabitEthernet1/6
switchport mode trunk
end
sh int gig1/6
GigabitEthernet1/6 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet Port, address is f0f7.553b.8945 (bia f0f7.553b.8945)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, Auto-speed, link type is auto, media type is 1000BaseSX
  input flow-control is off, output flow-control is off
  Last input never, output never, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 packets output, 0 bytes, 0 underruns
     0 lost carrier, 0 no carrier
Dear Samir,
when it shipped with cisco it was this IOS bootflash:cat4500e-universal.SPA.03.02.00.XO.150-2.XO.bin
I upgraded to latest IOS bootflash:cat4500e-universal.SPA.03.03.00.SG.151-1.SG.bin  still the status is the same.
Is there an option to select uplink type ( 1G or 10G ) and is there a speed miss match ?
As far i recall, also received switch with XO image which was fine for uplink, when switching to IOS uplink died. I will check my working image tomorrow and feedback.
Yes i have selected  hw-module uplink select gigabitethernet and there is no option in speed command except only one command speed nonegotiate.It will thankful for ur feedback of the IOS.
cat4500e-universalk9.SPA.03.03.00.SG.151-1.SG.bin
Your H/W module selection seems correct. Just in case do check speed at other end and make sure its also autonegotiate or matching.
you could also try switching over TX and RX and veriffy that you dont have a simple layer one issue, like incorrect patching etc..
Samir
Samir,
I have uploaded the above image but now the results are something strange when i do sh int gig1/6 on 4500 the status is connected but no neighbors are seen on this interface, And when i execute the sh int gig1/6 on the core 6500  the status is notconnected, How come it is possible that on 4506 end it is connected and the core 6506 end the int is showing notconnected.
It could be an option to verify the power supplies. May be there is not enough energy to make the supervisor works properly.
carlos,
IF it would have been the cause it would not have shown me in sh module OK status and also there no logs seen in the logging buffer for any power supply issues.
The problem was becz by the fibre cables are not spliced properly ,,when they change the cabling everything comes up smoothly.
