Catalyst 6509.
shuzaimi
Hi Guyz,
Allow me to paste some config that might be useful below. The problems are:-
1- Cant seem to get VLAN 1 up.
2- When the switch reloads/reboots it goes into RMONN> mode.
Building configuration...
Current configuration : 4195 bytes
version 12.2
mpls ldp logging neighbor-changes
no mls flow ip
no mls flow ipv6
no spanning-tree optimize bpdu transmission
diagnostic cns publish cisco.cns.device.diag_results
diagnostic cns subscribe cisco.cns.device.diag_commands
redundancy
mode rpr-plus
main-cpu
auto-sync running-config
auto-sync standard
vlan internal allocation policy ascending
c6509#sh int vlan1
Vlan1 is down, line protocol is down
Hardware is EtherSVI, address is 000f.f82e.2340 (bia 000f.f82e.2340)
Internet address is 10.45.100.5/16
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
L2 Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
L3 in Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes mcast
L3 out Switched: ucast: 0 pkt, 0 bytes mcast: 0 pkt, 0 bytes
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 interface resets
sh ver
IOS (tm) s72033_rp Software (s72033_rp-PK9S-M), Version 12.2(17a)SX4, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Thu 22-Apr-04 01:04 by pwade
Image text-base: 0x40008FBC, data-base: 0x41E56000
ROM: System Bootstrap, Version 12.2(14r)S9, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-PK9S-M), Version 12.2(17a)SX4, EARLY DEPL
c6509 uptime is 2 hours, 1 minute
Time since c6509 switched to active is 2 hours, 0 minutes
System returned to ROM by power-on (SP by power-on)
System image file is "sup-bootflash:s72033-pk9s-mz.122-17a.SX4.bin"
c6509#sh bootvar
BOOT variable =
CONFIG_FILE variable does not exist
BOOTLDR variable =
Standby is up
Standby has 458752K/65536K bytes of memory.
Standby BOOT variable =
Standby CONFIG_FILE variable does not exist
Standby BOOTLDR variable =
Standby Configuration register is 0x2102
Hope to get some expert advise from the forumers.
tQ
Please paste the output of show int vlan 1, show run, show vlan.
-amit singh
11 Replies 11
amit-singh
Level 8
Level 8
1.Do you have any host connected to Vlan 1. Without any host connected it will show down.
2.Well the first thing I would say that your bootvariable is empty. Please use the command " boot system flash sup-bootflash:s72033-pk9s-mz.122-17a.SX4.bin " and save it so that it always gets to the flash to get that file.
Another thhing that I would like to see is the config register setting on the Sup side. Please use the command " remote command switch show boot " to see the config register setting. I could be possible that your Sup doesnot have the correct settings and its going to rommon mode. You can also use command " remote login switch " to telnet into the switch and then run the same command.
HTH,
-amit singh
Thanks for your reply amit,
1. I have a win2k server connected to it but its still down. Cant seem to figure out why.
The details you've requested is here...
c6509#remote command switch show boot
BOOT variable = bootflash:s72033-pk9s-mz.122-17a.SX.bin,1
BOOTLDR variable =
However after adding system flash sup-bootflash:s72033-pk9s-mz.122-17a.SX4.bin , it still goes to rmonn 1>
I have to manually issue "boot" at the rmonn 1>
* This switch lost its configurations and settings previously. Nobody know what happened since it was left unattended for 2 months..
I really appreciate your assistance. Thanks again.
Something that i missed out..
After adding system flash sup-bootflash:s72033-pk9s-mz.122-17a.SX4.bin
System Bootstrap, Version 7.7(1)
Copyright (c) 1994-2003 by cisco Systems, Inc.
Cat6k-Sup720/SP processor with 524288 Kbytes of main memory
Autoboot executing command: "boot bootflash:s72033-pk9s-mz.122-17a.SX.bin"
open(): Open Error = -9
loadprog: error - on file open
boot: cannot load "bootflash:s72033-pk9s-mz.122-17a.SX.bin"
rommon 1 >
Did you see that line...switch is booting up with the wrong path..its looking the file in router's flash and its not there as the file is on the supervisor engine's flash.
See that you are in supervisor engine's rommon..
Cat6k-Sup720/SP processor with 524288 Kbytes of main memory-----------> this shows sup's rommon
Please check the config-register settings for the Sup engine.
Please forward me the output of " remote command switch show version " and " remote command switch show bootvar "
Please paste the output og command "set" when you are in rommon.
regards,
-amit singh
Hi again amit,here are the details..
rommon 1 > set
PS1=rommon ! >
LOG_PREFIX_VERSION=1
ACL_DENY=0
CRASHINFO=bootflash:crashinfo_20050517-034921
SLOTCACHE=cards;
BOOTLDR=
?=0
BOOT=bootflash:s72033-pk9s-mz.122-17a.SX.bin,1
RET_2_RTS=20:28:26 UTC Fri Jul 1 2005
BSI=0
RET_2_RCALTS=
rommon 2 >
c6509#rem comm swit sh ver
IOS (tm) s72033_sp Software (s72033_sp-SP-M), Version 12.2(17a)SX4, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Compiled Thu 22-Apr-04 01:13 by pwade
Image text-base: 0x40020FBC, data-base: 0x40D36000
ROM: System Bootstrap, Version 7.7(1)
BOOTLDR: s72033_sp Software (s72033_sp-SP-M), Version 12.2(17a)SX4, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
c6509 uptime is 56 minutes
Time since c6509 switched to active is 6 minutes
System image file is "bootflash:s72033-pk9s-mz.122-17a.SX4.bin"
cisco Catalyst 6000 (R7000) processor with 458752K/65536K bytes of memory.
Processor board ID SAL0819711A
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from power-on
X.25 software, Version 3.0.0.
68 Gigabit Ethernet/IEEE 802.3 interface(s)
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
c6509#rem comm swit sh bootva
BOOTLDR variable =
tQ.
I checked all the necessary settings and it seems to be fine. However the problem, is in the way your boot path has been added. Now what you do :
1. If you are on enable prompt, go to config t
(Config)#no boot system flash bootflash:
wr mem
(config)# boot system flash:sup-bootlfash:
wr mem
or 2. in rommon mode do :
rommon1> BOOT= >after this do not type anyhting it should be blank and press enter.
rommon2> sync
rommon3> BOOT:=sup-bootflash:
rommon4>sync
rommon5>boot
try this and let me know.
-amit singh
Thanks alot. It works. No more rmonn prompt, but the vlan1 is still down. Any suggestion? I other switches connected to it & the interfaces are up. Even the Gi interface where win2k server connected is up. VLAN 1 is still down.
Any suggestions?
tQ
-amit singh
Hi Amit,
Its alright now, just a few typing error on my side. Thank you alot for your kind assistance, help and guide. I appreciate it very much.
Do u by any chance know anything about cisco call manager? Just asking..
tQ again.
Hi Shuzaimi,
Thanks for the reply and appreciation.
I dont know much about the call manager but I can try to arrange some help. You can contact me direct at
toamitsingh@yahoo.com
regards,
-amit singh
Questions about Callmanager or any other IP Telephony (cisco ) product can be posted in the IP Communications section in the same forum.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
