Catalyst 8200/8300 Startup Changes to Using packages.conf Instead of .bin
Translator
Community Manager
Community Manager
I use the Catalyst 8200/8300.
The other day, I did an OS upgrade of IOS-XE, and there was a situation that the boot system setting specifies a .bin file instead of packages.conf on some devices.
Expected Configuration: boot system bootflash:packages.conf
Actual configuration: boot system flash bootflash:c8000be-universalk9.17.15.04.SPA.bin
I want to start using packages.conf. What kind of operation command do I need? Will it also be necessary to restart the system?
If you have any knowledge, we would appreciate it if you could answer.
Translator
Community Manager
Community Manager
In terms of service impact, the change of Installation mode (Bundle mode or Install mode) will cause a reboot.
I think that the work will generally follow the following flow.
(1) First, it is better to check the installation mode with the following command.
show version | include Installation mode is
(2) Then, fix the command of "boot system" to be "only" below. Delete the ".bin" designation with "no".
(3) "write memory" will update the "BOOT variable", so check if "bootflash:packages.conf" is now loaded.
show boot
write memory
show boot
(4) Then, in "install add file", specify the ".bin" file to convert to Install mode.
If you specify "prompt-level none", it will run until "Automatically restart".
Note: The behavior is checked on the C9800 of the same IOS-XE system.
install add file bootflash:<File> activate commit prompt-level none
(5) Finally, check if "bootflash:packages.conf" is specified in the "BOOT variable".
show boot
[Note]
By the way, some models are said to have discontinued Bundle mode in v17.18 and later.
Cisco IOS XE Bundle Boot Mode Will Be Discontinued After Release 17.18 – Product Bulletin - Cisco
https://www.cisco.com/c/en/us/products/collateral/ios-nx-os-software/ios-xe-17/ios-xe-bundle-boot-pb.html
Mark Elsen
    - It looks like the full upgrade procedure was not executed correctly  : verify current mode using
        show version | include Mode
      To sanitize the setup :    1) copy the bin file from cisco software downloads  through your local
                                               tftp server or via usb to the switch
                                           2) Expand the image to install mode:
                                                            request platform software package expand file flash:xxx.bin to flash:
                                           3) boot system flash:packages.conf
                                              write memory
                                              reload
                                            4) After boot , verify if the router is in Install Mode : show version | include Mode
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Translator
Community Manager
Community Manager
show boot
write memory
show boot
show boot
[Note]
Thank you for your reply.
By following the steps described above, we have changed to boot from packages.conf!
Thank you very much for the detailed and attentive professor.
