03-22-2006 02:26 AM - edited 03-03-2019 12:08 PM
sh vers
IOS (tm) C2600 Software (C2600-IS-M), Version 12.2(11)T11, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Wed 14-Apr-04 17:41 by hqluong
Image text-base: 0x8000809C, data-base: 0x816745DC
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
ROM: C2600 Software (C2600-IS-M), Version 12.2(11)T11, RELEASE SOFTWARE (fc1)
30a uptime is 5 weeks, 1 day, 22 hours, 23 minutes
System returned to ROM by reload at 12:45:47 CET Mon Feb 13 2006
System restarted at 12:48:37 CET Mon Feb 13 2006
System image file is "flash:c2600-is-mz.122-11.T11.bin"
cisco 2610 (MPC860) processor (revision 0x203) with 61440K/4096K bytes of memory.
Processor board ID JAD0539009D (2764277993)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
2 Ethernet/IEEE 802.3 interface(s)
1 ATM network interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Remark : the atm interface is here an WIC-1 ADSL
class-map match-all gold
match ip precedence 6
class-map match-all silver
match ip precedence 5
policy-map telin
class gold
bandwidth percent 85
class silver
bandwidth percent 10
class class-default
fair-queue
voice call carrier capacity active
mta receive maximum-recipients 0
interface Loopback0
ip address 10.120.8.10 255.255.255.255
interface ATM0/0
description === 02/751.06.09 ===
no ip address
load-interval 60
no atm ilmi-keepalive
dsl operating-mode auto
dsl enable-training-log
interface ATM0/0.1 point-to-point
bandwidth 512
ip address 10.120.4.38 255.255.255.252
pvc 8/35
vbr-nrt 512 512
interface ATM0/0.2 point-to-point
bandwidth 512
ip address 10.120.4.78 255.255.255.252
pvc 8/36
vbr-nrt 512 512
oam-pvc 0
encapsulation aal5snap
interface Ethernet0/0
description === KAVILV256-079 ===
30a#conf t
Enter configuration commands, one per line. End with CNTL/Z.
30a(config)#int atM0/0.2
30a(config-subif)#serv
30a(config-subif)#service-policy ou
30a(config-subif)#service-policy output telin
CBWFQ : Not supported on subinterfaces
30a(config-subif)#
03-22-2006 02:33 AM
The reason is that it has to be applied under the PVC. Try the following:
int atm0/0.2
pvc 8/36
Hope that helps - pls rate the post if it does.
Paresh
03-22-2006 03:23 AM
Thanks for the response ,
but under the pvc it is not possible
30a#conf t
30a(config)#int atm0/0.2
30a(config-subif)#pvc 8/36
30(config-if-atm-vc)#?
ATM virtual circuit configuration commands:
atm atm pvc commands
broadcast Pseudo-broadcast
cbr Enter Average Cell Rate in Kbps.
class-vc Configure default vc-class name
default Set a command to its defaults
dialer set dialer pool this pvc belongs to
encapsulation Select ATM Encapsulation for VC
exit-vc Exit from ATM VC configuration mode
ilmi Configure ILMI management
inarp Change the inverse arp timer on the PVC
ip addr inarp Assign an ip address to the atm interface through ATMInarp
no Negate a command or set its defaults
oam Configure oam parameters
oam-pvc Send oam cells on this pvc
pppoe PPPoE options
protocol Map an upper layer protocol to this connection.
ubr Configure Unspecified Bit Rate (UBR) for this interface
ubr+ Enter Peak Cell Rate(pcr)Minimum Cell Rate(mcr) in Kbps.
vbr-nrt Enter Variable Bit Rate (pcr)(scr)(bcs)
vbr-rt Enter Variable Bit Rate (pcr)(average)
vcci VCC Identifier
30(config-if-atm-vc)#serve
30(config-if-atm-vc)#service ?
% Unrecognized command
03-22-2006 03:36 AM
I just checked Feature Navigator and it appears that per-VC application of service-policies is not available on the 2610 platform at all. I'm not sure what you can do here ...
Paresh
