CCNA LAB
ahmed7882022
i have 2 ISDN 1603 routers
1 Catalyst 1900 switch
1 Frame Relay router 2520
i am a beginner of cisco
whats the best method to setup a CCNA Lab from these.
i have static internet IP From my ISP
i also have 2 numbers of DTE/DCE cable
hope someone will help me
JonathanUK
Level 3
Level 3
I would try and replave the 1900 switch if your budget allows you to as the 1900 switch isn't tested anymore on the CCNA Exam.
As you have three routers you could practice setting up static routes and routing protocols such as RIP,EIGRP,OSPF. THe CCNA sybex book has labs which you can follow.
You could have your two 1600 Routers connected upto your frame-relay router and you could implement frame-relay. You could also connect your two routers together to implement access-lists and setup loopback interfaces to test that they work properly.
I would practice on your routers doing basic setup so you get used to the different commands etc.
Hope that helps.
