CCX settings
madhu_mbx
Hi.. How do I make the WLAN Access Point as CCX enabled? I have Cisco Aironet 1130 AG series & 1230 AG series AP's/
Can some one help me out in doing the settings for ccx?
purohit_810
Level 5
Level 5
To be enable CCX please use open authentication with EAP..
To open EAP :
authentication open eap_methods
authentication network-eap eap_methods
See on URl:
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_configuration_example09186a00801c40b6.shtml
Dharmesh Purohit
Thanks Dharmesh.
Can you please let me know the following?
1. Does Cisco 1131AG series Access Point supports CCX?
2. Is setting up the EAP method, the only change to make it ccx enabled?
3. I would like to capture the Radio measurement messages && beacon frame from the AP. Is this EAP setting will do or should I change any other configuration at the AP?
