CDP message interval
Greetings,
We have about 15 routers and about the same number of switches. I'm getting ready to setup Cisco Network Assistant to manage our devices and it uses CDP. Is there a best practice on the message interval?
C
Edison Ortiz
Default setting is the best practice.
The only reason you would change the default setting, and note - it isn't a best practice, is if you were to configure ODR which relies on CDP for route advertisement.
HTH,
__
Edison.
Thanks, Edison. Works for me.
