CEF load-sharing
Thomas Schmitt
Hello
I'm not sure about load-sharing by CEF, how it works. Hope somebody can explain it for me:
For example I have two interfaces (f0/0 and f0/1) for equal-cost load-balancing. Now I set cef algorithm for layer4
(config)# ip cef load-sharing algorith include-ports destination
on interface f0/0
(config-if)# ip load-sharing per-packet
on f0/1
(config-if)# ip load-sharing per-destination
What happens now? both interfaces have a route to some host, for example 1.1.1.1. I would like to load-share my http traffic to 1.1.1.1:80.
Global cef config creates one hash for 1.1.1.1:80, so all the traffic to 1.1.1.1:80 should use only one interface, lets say f0/0. But cef config on f0/0 would like to share the traffic per packet, and f0/1 per destination... So I think i do not understand something here.
And one more thing - if i have multiple tunnel interfaces, exiting the same physical interface, so where should i configure load-sharing, on tunnel interfaces or on the physical interface?
Thank you in advice
Hello, Dmytro.
I guess "show ip cef " could reveal you how CEF treats your configuration.
It will show, if it's per-packet.
Please remember, that per-packet sharing could lead to packet reordering that could negativly impact application performance or even lead to crash (in case of UDP or some legacy TCP/IP implementation).
