CEF on Routers Vs CEF on Catalyst Switches
mohammedmahmoud
Level 11
Level 11
I just wanted to make sure of the differnce of CEF running on Cisco router and Cisco Catalyst switch --> CEF is implemented in hardware (ASICs) in the case of the Catalyst switches
But the CEF has the same concept in both --> FIB and Adj tables
Thanks in advance.
pkhatri
Level 11
Level 11
Regardless of whether CEF is implemented in hardware or software, the operation of CEF is the same.
Hope that helps - pls rate posts that help.
Paresh
