Cell Network problem
alerozier
I'm new in this forum.
In attach you can find a pkt zipped file about a network.
Smartphone0 is unable to reach any 10.50.1.XX device.
all router are configured by eigpr and all 10.50.XX are able to reach each other.
what am I wrong?
Thank you for helping me
Mark Elsen
 - Post here : https://learningnetwork.cisco.com/s/topic/0TO6e000000WEorGAG/packet-tracer
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
M02@rt37
Hello @alerozier
Smartphone is using its 4G connection. Your smartphone has got IP address and ping its Gateway, hosted on a Central Office server.... but there's no routing after it....
You need a router attached to the Backbone interface of your Central-Office-Server. Like this:
Also @alerozier, take care of IP address of Backbone interface on Central Office server:
IP and Gateway are not in the same subnet! You have a /29 (255.255.255.248) ; network address is 10.50.1.32/29...next subnet is 10.50.1.36/29. Then you have configured a network address on that interface.
So, I modify the IP of that servver --> 10.50.1.33/29
Fa 0/0 on my router, interface facing that server, IP address is 10.50.1.34/29
I add a static router on that router to reach SmartPhone subnet [172.16.1.0/24]
Now Smartphone Ping the Router Fa0/0 interface !!!!!
Please, do it this way, starting with that Router acting as your Gateway !
Best regards
Martin L
PT comes with some samples; I would look for example of smartphone connection probably in cellular or wireless folder(s). Open PT, go to file>open samples and look for sample of smartphone connection
PT is just a simulator , not real IOS; it may have some "strict ways of doing things"
Regards, ML
**Please Rate All Helpful Responses **
