Change CISCO 1603 by cisco 801??
fitou0013
I have buy a new CISCO 801 for change mys CISCO 1603.
I save my configuration but when I restore it on the 801 it's not good.
My CISCO 1603 was IOS 11 and my CISCO 801 IOS 12.1.
Can you help me??
I joint my configuration
Harold Ritter
Can you tell us what doesn't work. From what I can see only the physical interfaces (ethernet0 and bri0) might need to be changed to fit the 801.
Hope this helps,
When I initialize the 801 i have two interface Ethernet0 and BRI0.
On BRI0 I add "no shutdown"
But on the 1603 there isnt this parameter.
THe links are OK.
The routeur can connect to the remote network.
Sorry I not a specialist CISCO
You should be fine then. The "no shutdown" is just to activate the interface and is not required if the interface is already activated.
Hope his helps,
Yes of course ;)
I test my configuration with Cisco ConfigMaker and some parameter are not supported..
Can you tell me how debug that on the cisco?
