Changeover between ISPs
semigr-cisco
Hello All!
Suppose my Cisco 3925E router is connected to 2 ISPs via 2 tagged VLANs on one physical interface. It works with one provider normally. Is it possible to configure the router without BGP so that it will change over to the second provider if the current one fails?
Ivan Krimmel
Level 7
Level 7
Hi!
I think a mix of IP SLA + object tracking configuration would do the magic here.
HTH,
Ivan.
douhanm
Sure in many different ways, simplest is two static routes with different admin distance , more advanced is ip sla using object tracking
static default with tuned AD will just black-hole the traffic after the main ISP has failed, as it doesn't have a clue about the remote end's status.
