changing a subnet mask in production
michael18
I have four SVIs in the same HSRP group. I need to increase the size of the subnet by changing from /22 to /21. the SVI IP and gateway wont change, just the mask. Is it safe to do this in production hours or can it cause issues?
marce1000
  - I think it cause issues , because there 'is also HSRP' ; ref https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/9-x/unicast/configuration/guide/l3_cli_nxos/l3_hsrp.pdf
     >....Guidelines and Limitations for HSRP
     >For IPv4, the virtual IP address must be in the same subnet as the interface IP address.
     There could be unwanted side effects on  a hot-production environment. If you decide to
     proceed the use the command terminal monitor on the switch to get console messages too.
  M.
marce1000
  M.
Thanks Marce
Ill do it out of hours to be on the safe side.
