alexandru.coles
Beginner
Changing next-hop for EBGP peer routes
Is it possible to change the next-hop of some updates received through eBGP? Let's say the customer receives a flood and wants to advertise to the ISP a /32 prefix so the filtering occurs at the network edge. I was thinking something like:
PE config:
interface Null0
no ip unreachables
end
router bgp 100
bgp router-id 192.168.255.14
no bgp default ipv4-unicast
no bgp default route-target filter
bgp log-neighbor-changes
neighbor 192.168.2.2 remote-as 102
neighbor 192.168.2.2 update-source Ethernet0
address-family ipv4
neighbor 192.168.2.2 activate
neighbor 192.168.2.2 route-map InboundM in
no auto-summary
no synchronization
ip prefix-list prfx seq 5 permit 0.0.0.0/0 ge 32
route-map InboundM permit 10
match ip address prefix-list prfx
set ip next-hop 192.0.3.1
set origin igp
set community no-export
route-map InboundM permit 20
ip route 192.0.3.1 255.255.255.255 null 0
Unfortunately:
PE_XXX#sh ip bgp 69.0.0.1
BGP routing table entry for 69.0.0.1/32, version 3286
Paths: (1 available, no best path)
Not advertised to any peer
102
192.0.3.1 (inaccessible) from 192.168.2.2 (192.168.2.2)
Origin IGP, metric 0, localpref 100, valid, external
Community: no-export
PE_XXX#sh ip bgp 69.0.0.0
BGP routing table entry for 69.0.0.0/24, version 7
Paths: (1 available, best #1, table Default-IP-Routing-Table)
Advertised to non peer-group peers:
192.168.255.2 192.168.255.13
102
192.168.2.2 from 192.168.2.2 (192.168.2.2)
Origin IGP, metric 0, localpref 100, valid, external, best
PE_XXX#sh ip route 192.0.3.1
Routing entry for 192.0.3.1/32
Known via "static", distance 1, metric 0 (connected)
Routing Descriptor Blocks:
* directly connected, via Null0
Route metric is 0, traffic share count is 1
I want to make a step further from the blackhole routing described in the Nanog docs, so I don't have to manually provision the static route(s) that gets redistributed by iBGP and trigger blackholing, and to also allow the customer to announce me long prefixes for me to filter out dynamically.
Still, it doesn't seem to work as expected, as you can see from the output the /32 prefix doesn't get advertised with the 192.0.3.1 next-hop to be filtered out at the edge.
Alexandru
1 REPLY 1
alexandru.coles
Beginner
Ok, I've found out what the problem was. It seems that configuring the eBGP session as ebgp-multihop works. Here's the output:
router bgp YYY
neighbor 192.168.2.2 remote-as XXX
neighbor 192.168.2.2 description *** Customer ***
neighbor 192.168.2.2 ebgp-multihop 255
address-family ipv4
neighbor 192.168.2.2 send-community
neighbor 192.168.2.2 route-map Inbound in
no auto-summary
no synchronization
exit-address-family
ip route 192.0.3.0 255.255.255.0 Null0 tag 6969
ip prefix-list pref32 seq 5 permit 0.0.0.0/0 ge 32
route-map Inbound permit 10
match ip address prefix-list pref32
set origin igp
route-map Inbound permit 20
The route gets redistributed with 192.0.3.1 as next hop, and traffic gets filtered out at the edge.
PE_X_#sh ip cef 69.0.0.1
69.0.0.1/32, version 19162, epoch 0
0 packets, 0 bytes
tag information from 192.0.3.1/32, shared
local tag: implicit-null
via 192.0.3.1, 0 dependencies, recursive
next hop 192.0.3.1, Null0 via 192.0.3.0/24
valid null (drop) adjacency
Alexandru
