Channel Group is not working with Media Converter
azizur-rahman
We are facing problem to establish a redundancy link between two office.
there are two fiber link between two offices and connected with WS-C2960X-24TS-LL via media converter. One media converter is 10/100/1000 and another is 10/100.
When we connect two UTP cable between media converter and switch, one port shows amber.
We have done the following configuration on the switches:
interface range gigabitethernet0/1-2
description ##SP LINK##
channel-group 2 mode active
Please advise us.
Thanking You-
Azizur Rahman
Tagir Temirgaliyev
please share
sh runn
sh int g0/1
sh int g0/2
Dear Tagir,
Please find the below:
show running-config:
Building configuration...
Current configuration : 3354 bytes
! Last configuration change at 08:45:13 UTC Sat Apr 9 2016
! NVRAM config last updated at 08:39:38 UTC Sat Apr 9 2016
version 15.0
no service pad
hostname WAN-SW-KBS
boot-start-marker
boot-end-marker
no aaa new-model
crypto pki trustpoint TP-self-signed-2322400384
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2322400384
revocation-check none
rsakeypair TP-self-signed-2322400384
crypto pki certificate chain TP-self-signed-2322400384
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 32333232 34303033 3834301E 170D3136 30343039 30373030
33325A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 33323234
30303338 3430819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100BE7A A59CD67C CD58BCC3 FDFDA3C8 BE570CBE 3033B69F 50C36538 E43B96D2
6E2A38EF 398A59C6 2DDE0B06 AD93A0F5 653D7FCF B15E7AC1 0A8B65D8 5DAB94B1
A894E0BE 1D1148AC 3A6BA460 288D2149 A432FF55 51473754 AC37E05C 15E8215D
5BBF3840 9A7CEE81 BEF26867 72568C5F 9F7F017B 9E7FD3D8 C9E8B230 2D51E20C
AF750203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 14ACF336 E665F758 C85C00CD 52286683 FDC43BF9 D8301D06
03551D0E 04160414 ACF336E6 65F758C8 5C00CD52 286683FD C43BF9D8 300D0609
2A864886 F70D0101 05050003 81810068 E9D495D5 F6D3213E C1C85457 68305DA8
--More-- 4C13F35A 6786725A 3CFDC460 1434C608 64B04EC7 E4FD6DD9 E0FFA083 4292571A
6F35489D 54851F0A 20036A91 241CB7B0 E40D9739 9465FDF8 BFBF9C6F AB6764BE
523B4900 27790F71 472ADD0F A2189F2E 884F8DA9 E7449D09 6CB67FDC 8DA93041
AF3D9135 75E16FE8 AAD70CED 5DD8F4
quit
spanning-tree mode pvst
vlan internal allocation policy ascending
interface Port-channel1
interface Port-channel2
interface FastEthernet0
no ip address
interface GigabitEthernet0/1
description ##USE FOR SP LINK##
channel-group 2 mode on
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet0/25
channel-group 1 mode active
interface GigabitEthernet0/26
interface Vlan1
no ip address
ip http server
ip http secure-server
--More-- !
line con 0
line vty 0 4
login
line vty 5 15
login
end
show interfaces gigabitEthernet 0/1:
GigabitEthernet0/1 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is ac7e.8a6d.0481 (bia ac7e.8a6d.0481)
Description: ##USE FOR SP LINK##
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
reliability 255/255, txload 1/255, rxload 2/255
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:51, output 00:00:06, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 10711000 bits/sec, 1609 packets/sec
5 minute output rate 2318000 bits/sec, 1168 packets/sec
15707354 packets input, 12500492374 bytes, 0 no buffer
Received 194 broadcasts (194 multicasts)
0 watchdog, 194 multicast, 0 pause input
--More-- 0 input packets with dribble condition detected
11660556 packets output, 2733444646 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
show interfaces gigabitEthernet 0/2:
GigabitEthernet0/2 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is ac7e.8a6d.0482 (bia ac7e.8a6d.0482)
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
Last input never, output 02:15:52, output hang never
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
198 packets output, 18206 bytes, 0 underruns
Thanking You-
Azizur Rahman
your port g0/1 is 1G and g0/2 is 100mb, so portchannel is impossible. and useless. use usual stp. so 1G will be working and 100mb will be spare
