channelised DS3 module on 7200
prathikr
Hello All ,
Need to know if 7200 supports channelised DS3 , we use PA-2T3 card only to realise later that it supports only clear-channel
Kinldy let me know if we can use any modules that support channelised DS3 on 7200
Appreciate quick response.
5 Replies 5
Thank you fir the quick response venperum , this should help
Adding to venperum
Take look at this also,  PA-MC-2T3-EC
www.cisco.com/c/en/us/td/docs/interfaces_modules/port_adapters/install_upgrade/multichannel_serial/pa-mc-t3-ec_install_config/mc-t3ec.pdf
Masoud
Thank you Masoud ,appreciate your help
You are most welcome.
