Checksum Error in Cisco 1841
alienson13
Can somone please help, the router is always giving the below error:
Error : compressed image checksum is incorrect 0xDC5C5348
        Expected a checksum of 0x066C5349
I have uploaded a new firmware but same issue after booting, I have check the MD5 checksum in the image and Cisco and they are matching and verified, what could be the reason for all of this ??
Thanks in advance for the help.
6 Replies 6
Raju Sekharan
if  the image is good, check the flash.
I have checked the flash, I can access it from any card reader and format, copy...etc, and from the rommon If I issue the command "dir flash:" I can see the IOS file inside the flash, so I don't think it is from the flash card, any other ideas ??
Hello
There are 3 chances
1. Software Image is currepected : Since it is verified ok, that option is ruled out
2. Flash disk curreption: You can format the flash ( do not reload)  and copy a fresh copy of the image and see whether the issue reappear
3. A software bug which shows this error.. ( what is the IOS Name you are using )
regards
Harish
I have formated the flash before and reloaded new firmware but still same result, if the flash is corrupted will I be able to see the directory and see the IOS on it ?
The software I'm using IOS i'm using is
c1841-ipbasek9-mz.124-24.T3.bin
I have tried with other IOSs and got the same checksum error, can it be the RAM is faulty or something like that ??
The full error is as below:
program load complete, entry point: 0x8000f000, size: 0x12e6ec8
Error : compressed image checksum is incorrect 0xF5F020B7
        Expected a checksum of 0x1F1020B8
*** System received a Software forced crash ***
signal= 0x17, code= 0x5, context= 0x80014340
PC = 0x8000f0d4, Cause = 0x20, Status Reg = 0x3041e803
System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Thanks for the help
Hello
Alright, as per cisco, if you face a software crash along with this error , it can be a memory issue as well ( link provided)
http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a008010260c.shtml
by the way , there is no matching bug in your IOS
regards
Harish
Please rate helpful posts!
Thanks A lot Harish for the help, It seems to be a hardware issue for sure, but which memory they are refering to ? the RAM or the Compact Flash ??
I will try to see if I can get another CF to test with
