CHUNKBADMAGIC???
riju
My IOS is 12.3(14)T1. I did a ping with large size packets(20000-35000). Ping result is good, but got some messages:
000413: Apr 25 14:29:50.951 XXX: %SYS-2-CHUNKBADMAGIC: Bad magic
number in chu
nk header, chunk 0 data 443E49B0 chunkmagic 0 chunk_freemagic
43CCD478
-Process= "<interrupt level>", ipl= 4
-Traceback= 0x40AA598C 0x400BA458 0x402F8D44 0x40042968 0x40042C4C
0x4001031C 0x
400116BC
000414: Apr 25 14:30:01.047 XXX: %SYS-2-CHUNKBADMAGIC: Bad magic
number in chu
nk header, chunk 0 data 443E4898 chunkmagic 0 chunk_freemagic
43CD1A28
0x4001031C 0x
400116BC
000415: Apr 25 14:30:14.247 XXX: %SYS-2-CHUNKBADMAGIC: Bad magic
number in chu
nk header, chunk 0 data 443E4898 chunkmagic 43CCF3D4
chunk_freemagic 43CCECDC
-Process= "<interrupt level>", ipl= 4, pid= 74
0x4001031C 0x
400116BC
000416: Apr 25 14:30:27.807 XXX: %SYS-2-CHUNKBADMAGIC: Bad magic
number in chu
nk header, chunk 0 data 443E4898 chunkmagic 43CD2818
chunk_freemagic 43CCF058
0x4001031C 0x
400116BC
What does this means?
Richard Burts
I had an issue which included error messages about CHUNKBADMAGIC on a router running the T train of 12.3 code. I opened a case with TAC. They agreed that it was some kind of bug in IOS. We never were quite sure what triggered it. They advised that I change IOS release levels. I suspect that it is a similar issue in your case.
Rick
Rick
Can you please give your case number, so I can refer to that also. My IOS is 12.3(14)T1. Which was the IOS you had repoerted to TAC?
My TAC case was 600459735. The TAC engineer gave me two bug IDs that he thought were related: CSCee65576 and CSCee57895.
For us the problem stopped when we upgraded to 12.3(8)T4
Rick
Rick
