CIDR help
gurkamal01
Can anyone tell me why  /19 and smaller prefixes have less routing tables than /20, /21, .... for  classC
This is done with major Tier 1 ISP's
Will appreciate an response
Jon Marshall
gurkamal01 wrote:
Not sure i fully understand your question so if i have misunderstood please clarify.
A /19 ie. 255.255.224.0 would give you 32 useable Class C subnets (if that is what you wanted to use)
A /20 ie. 255.255.240.0 would give you 16 useable Class Cs
A /21 ie. 255.255.248.0 would give you 8 useable Class Cs
so you can see that you would need 4 /21s  ie.  4 * 8 = 32 to represent one /19 and 2 /20s ie. 2 * 16 = 32 to represent one /19.
So to represent 32 class C subnets in the routing table you would need  4 entries using /21s, 2 entries using /20s and only one entry using a /19. This is how using /19s means fewer entries in the routing table.
Note this is assuming that the 32 class C subnets could indeed be summarised with a /19.
Jon
Jon Marshall
gurkamal01 wrote:
Jon
Thank for the response
As per your reply you stated ....." 4 * 8= 32 to represent one /19 and 2 /20s ie. 2 * 16 = 32 to represent one /19".
Can you please tell me how we got the 8 and 16 for /21 and /20 respectively
Well, you could do it in binary and that would show you for sure. But a quick way to work these things out is to simply do the following -
/19 = 255.255.224.0   so take the first octet that is not 255, in this case it is the 3rd octet and it is 224. Then simply do 256 - 224 = 32 so you have 32 useable class Cs
/20 = 255.255.240.0  so 256 - 240 = 16 class Cs
/21 = 255.255.248.0  so 256 - 248 = 8 class Cs
Jon
