10-11-2010 09:06 AM - edited 03-04-2019 10:04 AM
Is it possible to restrict all mac addresses and allow a small list of mac addresses from accessing ports fa 1 - 4? Basically, I want to allow access to one laptop.
System image file is "flash:c1700-k9o3sy7-mz.124-25b.bin"
Solved! Go to Solution.
10-11-2010 01:03 PM
One of the restrictions i noticed in the 1700's was "Mac Address table manipulation" so based on that I would say
No, you can't do that on this device. It is EOS/EOL now.
10-11-2010 01:03 PM
10-11-2010 01:06 PM
Thank you for the response.
I just looked it up here and you're correct.
