thomas.c.wright
Beginner
Cisco 1721 and WIC-1DSU-T1-V2 configuration
I just purchased a refurbished Cisco 1721 router with a WIC-1DSU-T1-V2. I was able to connect to the console via serial and performed the initial setup for Ethernet0; however, I do not know where to begin to setup the WIC, and I don't want to pay for someone else to configure it if I can get the information here. My ISP gave me the following information (I am hiding the IP's for security reasons):
IP Address Allocation: aaa.aaa.aaa.aaa/28
WAN-Side: bbb.bbb.bbb.bbb/30
Network IP: ccc.ccc.ccc.ccc
Broadcast IP: ddd.ddd.ddd.ddd
Subnet mask: 255.255.255.240
Available IP addresses: eee.eee.eee.eee-eee
Gateway IP (Router Address): fff.fff.fff.fff
The dmarc will not be extended to my server room until the end of the week.
My question is, once I plug the dmarc into the WIC, will the router automatically pull the information from the ISP? Or will I need to manually configure the WIC? If so, I would appreciate quick setup steps.
3 REPLIES 3
davidmoum
Beginner
Do you see the serial module when you perform a "show ver" or "sho run" command? If so, you need to know whether to configure for frame-relay or full T1 setup. You also need to find out the type of encapsulation the ISP is using on their end. I do not think the serial interface (WIC card)can be setup to get ip information from the ISP DHCP server like residential router can. Please provide more info so we can help further. Thanks.
David
Hi David,
Thank you for your response. The router shows the following information when I perform the "show ver" command:
User Access Verification
Password:
Cisco1721>enable
Password:
Cisco1721#show ver
IOS (tm) C1700 Software (C1700-Y-M), Version 12.3(16), RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Wed 24-Aug-05 00:28 by ssearch
Image text-base: 0x8000816C, data-base: 0x80A654A4
ROM: System Bootstrap, Version 12.2(7r)XM1, RELEASE SOFTWARE (fc1)
ROM: C1700 Software (C1700-Y-M), Version 12.3(16), RELEASE SOFTWARE (fc4)
Cisco1721 uptime is 1 day, 15 hours, 50 minutes
System restarted at 11:01:07 UTC Thu Dec 28 2006
System image file is "flash:c1700-y-mz.123-16.bin"
cisco 1721 (MPC860P) processor (revision 0x100) with 28352K/4416K bytes of memor
y.
Processor board ID FOC06170R7V (4141028887), with hardware revision 0000
MPC860P processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
WIC T1-DSU
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Cisco1721#
When I perform the "sho run" command I get the following results:
Current configuration : 743 bytes
! No configuration change since last restart
! NVRAM config last updated at 11:05:02 UTC Thu Dec 28 2006
version 12.3
hostname Cisco1721
boot-start-marker
boot-end-marker
enable secret 5 *******
enable password *******
no aaa new-model
ip subnet-zero
no ip routing
no ip cef
interface FastEthernet0
ip address 172.16.5.254 255.255.255.0
no ip route-cache
speed auto
full-duplex
interface Serial0
no ip address
no ip route-cache
shutdown
ip classless
no ip http server
snmp-server community ********* RO
line con 0
line aux 0
line vty 0 4
password *******
login
end
Cisco1721#
The configuration is for a full 1.5 MB T1. I'm not sure of the encapsulation, but I believe it is HDLC. I am waiting for confirmation from my ISP.
miclacs13
Beginner
Hi Thomas,
You must know the details such as below and configure under "interface config mode":
-clock source (depends on your telco)
-framing and line coding (depends on your telco)
-timeslots (depends on your access bandwidth)
-and of course your IP address details
for more info click below;
http://www.cisco.com/warp/public/116/t1_wic1.html
Rate if this helps.
Br,
Mike
