Cisco 1721 Problem
Joshua.M.Levine
I am having an issue with a Cisco 1721 router. I recently obtained this through unit supply and we have been having a problem with the router staying up and running. The router reboots repeatedly and indefinitely unless left unplugged for 20 minutes after being up for only a short while. The system displays, via a hyperterm window, the system bootstrap message and repeats it for an indefinite period. Any ideas what it could be?
thisisshanky
Level 11
Level 11
Could be a corrupt IOS image on flash file, or no file at all in flash. Either ways, paste the output on the screen and we can help you from there.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
System Bootstrap, Verison 12.2(7r)XM2 Release Software
TAC Support: HTTP://www.cisco.com/tac
Copyright (c) 2003 by Cisco Systems, Inc.
This is the message that is repeated indefinitely after the router reboots itself after being on for a few minutes.
After powering the router off (once the continuous reboot cycle starts), it displays this message and then halts, I cant get any keystrokes sent to it, nor can I do anything with the router. The following lights remain lit once a reboot is performed
Power
OK
WIC0
WIC1
ACT/CH1
Any ideas?
Dear J,
Its seems there's some problem in ur IOS may be its crashed/Corrupt as Thisisshanky said , Secondly, is this the full output. Thirdly please remove any WIC installed in it and then try booting also please maket the flash/ DRAM sit properly on the Motherboard it may be loose.
Please IM me at my yahoo id ephraim_mani@yahoo.com for more.
EM
