04-21-2005 12:51 AM - edited 03-03-2019 09:21 AM
Hello NG,
i have a great problem with one of my Cisco 1751.
2 offices with static ip and one with a dynamic ip-adress.
The office with the dynamic ip-adress was using before changing the provider a static ip-adress with sdsl. Now we are using adsl with dynamic ip-adress.
The internet and email is working fine, but the vpn tunnels are not working any more. It needs a start/end point.
How can it be solved? Perhaps with DynDns-host entry?
The ip-Adress could be updated with Linux-host!
One hot hint would be helpful.
Thanks in advance
p.s. the actual not working tunnel is:
interface Tunnel0
ip unnumbered FastEthernet0/0
tunnel source 217.110.xxx.xxx
tunnel destination 195.30.xxx.xxx
tunnel mode ipip
==> The entry "tunnel source 217.110.xxx.xxx" has to be changed into a valid NAME, e.g. vpntunnel1.dyndns.org
How can this be solved?????
04-21-2005 04:37 AM
There is a solution.
The virtual interface Dialer1 !
interface Tunnel0
tunnel source Dialer1
04-21-2005 04:39 AM
It works with t-online and netcologne.
1.) The accesslist has to be changed!!!
2.) crypto isakmp key ddddd address 0.0.0.0 0.0.0.0
(between the 4 zero´s are one space!)
