Cisco 1760 with 1 WIC-4ESW card
jgrasso77
I am trying to connect my Cisco 1760 router inline so I can use it and practice my ACL's.
I want it to go in this sequence:   linksys BEFSX41 firewall router switchport >>>>> Built in FA0/0
 port on my 1760 router >>>>>>  out the FA1/1 port on the WIC-4ESW card >>>>>>>into the
NIC card on my computer.
I want the internet to pass through the 1760 router and be filtered by the 1760 router with my ACL's.
I can put the ACL's in later, but at this point I really just want end to end connectivity.
Would you look at my show run and other outputs and tell me what may be wrong?
I do not know if I need the dhcp in there.  Or if I need a routing protocol like RIP in
there.  The Linksys router can perform rip as well if I turn it on in the linksys.
Currently rip is off on the linksys.  I have the linksys and the 1760 in the same network of
 192.168.1.0 255.255.255.0
the linksys is set to 192.168.1.1 for administration
It starts DHCP at 192.168.1.2 and uses only 100 addresses and goes up to 192.168.1.102
All being in the 255.255.255.0 subnet mask.
You can see from the below output what I have on the 1760 router.
Please help me get the connectivity I need.
I understand I cannot assign I.P. addresses to switchports, so that is a little confusing as
to what to do there.  What I.P. address is the NIC on my computer
going to be seeing?
As you can see from the output, it says the words Vlan, but when I do a
show vlans command, it says there are no virtual lans configured.
It is true I do not have any vlans  assigned to any interfaces.
Do I have to though?
UPDATE:
I turned one of the switchports on the WIC into a trunk and it did start to work.  I was flowing streaming video through it just fine.  But minutes later the video stopped and I couldn't access any sites until I connected the Ethernet cables and bypassed the router.
Something dynamic must have been occurring in the router to make it stop allowing traffic through.
Please help me get this setup working.
Jason G
Router1760#show run
Building configuration...
Current configuration : 1547 bytes
version 12.4
hostname Router1760
boot-start-marker
boot-end-marker
enable password cisco
no aaa new-model
tdm clock T1 0/0 both export line
voice-card 0
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.102 192.168.1.253
ip dhcp pool love
   network 192.168.1.0 255.255.255.0
   domain-name melisa.com
   default-router 192.168.1.1 255.255.255.0
   dns-server 205.171.3.25
   lease 30 2 7
no ip domain lookup
archive
 log config
  hidekeys
controller T1 0/0
 framing esf
 linecode b8zs
interface FastEthernet0/0
 ip address 192.168.1.53 255.255.255.0
 speed auto
 full-duplex
interface FastEthernet1/1
interface FastEthernet1/2
 duplex full
 speed 100
interface FastEthernet1/3
interface FastEthernet1/4
interface Vlan1
 no ip address
interface Vlan7
 ip address 10.0.0.1 255.0.0.0
ip default-gateway 192.168.0.1
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
banner login ^C Cisco 1760 Router. Goal:  Make the ESW ports routable.^C
banner motd ^CMight have to add vlans.   And assign Vlans subnets. May have to add a routing protocol to communicate between vlans.^C
line con 0
 exec-timeout 0 0
 logging synchronous
 login
line aux 0
line vty 0 4
 exec-timeout 180 0
 privilege level 15
 password cisco
 login
 transport input telnet ssh
end
Router1760#
Router1760#show ip int brie
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            192.168.1.53    YES NVRAM  up                    up
FastEthernet1/1            unassigned      YES unset  up                    up
FastEthernet1/2            unassigned      YES unset  up                    down
FastEthernet1/3            unassigned      YES unset  up                    down
FastEthernet1/4            unassigned      YES unset  up                    down
Vlan1                      unassigned      YES NVRAM  up                    up
Vlan7                      10.0.0.1        YES NVRAM  up                    down
Router1760#
Router1760#show interface fa0/0
FastEthernet0/0 is up, line protocol is down
  Hardware is PQUICC_FEC, address is 0014.a820.107c (bia 0014.a820.107c)
  Internet address is 192.168.1.53/24
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, Auto Speed, 100BaseTX/FX
  Last input never, output 00:00:03, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     304 packets output, 18240 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     1 unknown protocol drops
     0 lost carrier, 0 no carrier
Router1760#
Router1760#show int fa1/1
FastEthernet1/1 is up, line protocol is down
  Hardware is Fast Ethernet, address is 0013.c433.892c (bia 0013.c433.892c)
  Auto-duplex, Auto-speed
  Last input never, output never, output hang never
     0 packets input, 0 bytes, 0 no buffer
     0 packets output, 0 bytes, 0 underruns
Router1760#
Router1760#show vlans
No Virtual LANs configured.
Router1760#
6 Replies 6
johnd2310
Level 8
Level 8
You do not need dhcp between the BEFSX41 and the 1760. The dhcp should be configured for the you lan/computer.
ip dhcp excluded-address 10.0.0.1
ip dhcp pool LAN
   network 10.0.0.0 255.255.255.0
   default-router 10.0.0.1
   lease 30 2 7
To show vlans try the following command: show vlan-switch
To create vlans try the following command: vlan-database
I will assume you want to use interface vlan 7 for you lan/Pc since it is already created.
interface Vlan7
 no ip proxy-arp
 no ip redirects
 ip address 10.0.0.1 255.255.255.0
since you are connecting the PC to port fa1/1, you need to put that interface into vlan 7
switchport mode access
switchport access vlan 7
spanning-tree portfast
 To allow traffic to route to the Internet,  you need to add a static route pointing to the linksys BEFSX41 router.
ip route 0.0.0.0 0.0.0.0 192.168.1.1
To allow traffic from the Internet/linksys router to get to the pc, you need a static route on the linksys to the 10.0.0.0 255.255.255.0 network pointing to 192.168.1.53
On the linksys router ensure you have configured NAT for the lan subnet 10.0.0.0 255.255.255.0
John
**Please rate posts you find helpful**
Yeah, I do have some VLANS in there.  I could take them out.  The reason I had the 192.168.1.53 is because it is the same network as the linksys.
It may complicate things if I try to keep the 10 network.
Can you describe to me how to do this without the 10 network?  I am a little confused because the main F0/0 port on the router is not a switchport.  it is a router port.  So it is a member of all vlans.
If I removed the 10 network on vlan 7, do I still need a vlan?  And if so, could I just make the vlan 7 the 192.168.1.0 network.   I am just trying to simplify things.   I will try it your original way, but please do help me with this latest question.
Thanks.
You need 192.168.1.53 on Fa0/0 because that is the link to the Linksys and should be on the same network as the linksys. Fa0/0 is a routed port, it's not a member of any vlan. You can change the ip address  of vlan 7 but for now leave it and get everything working before changing. Try the config i have given you and see  if that works.
John
So I assume that since the FA1/1 on the WIX4ESW card is going to be connected to my PC, I will need to change the PC's NIC to the 10 network?
Then the routers routed port will still be the 192.168.1.53, and I will have to adjust the BEFSX41 so that they are in the same network?
But how specifically do I enable NAT on the Linksys?  I do not mean that I do not know how to go in and enable NAT.  I just mean:  "What do I make the NAT do.  Can you type it out?
Like NAT from where to where?
You wrote: "On the linksys router ensure you have configured NAT for the lan subnet 10.0.0.0 255.255.255.0
So do I go into the linksys and make it so everything gets natted to that subnet?  I uploaded a screenshot of the linksys NAT page.  Maybe you could help me out with what I need to enter there.
In Cisco IOS lingo, what would that look like?
  I will post a "Show Run" of the 1760 router after I post this message.
Thank You.
I finally got it working.   It is currently:   NIC>>>>1760 Router>>>>>Linksys BEFSX41 Firewall Router>>>>>>>DSL modem>>>>Phone Line
And it is carrying the Internet in both directions.
Thanks for the help
I attached a file that shows pics of all the current configs that made it work.
This Show Run post is the one I said I would post that is is reference to the post right after this one.   It did not put this post after my last post, that is why it is showing up before the post it is in reference to, so you will need to read the next post in order to know what this one is about.
Thank You.
Router1760#show run
Current configuration : 1450 bytes
version 12.4
hostname Router1760
boot-start-marker
boot-end-marker
no aaa new-model
voice-card 0
ip cef
no ip domain lookup
archive
 log config
  hidekeys
controller T1 0/0
 framing esf
 linecode b8zs
 speed auto
 full-duplex
 switchport mode trunk
 duplex full
 speed 100
interface Vlan1
 no ip address
interface Vlan7
 no ip redirects
 no ip proxy-arp
no ip http server
control-plane
line con 0
 exec-timeout 0 0
 logging synchronous
 login
line aux 0
line vty 0 4
 exec-timeout 180 0
 privilege level 15
 password cisco
 login
end
Router1760#
