12-01-2017 02:59 PM - edited 03-05-2019 09:34 AM
hy,
I have a Cisco 1800 with two wan :
wan1, powered by my fiber Box in FE0
and wan 2 powered by 4g Box in FE1.
In the LAN of my Fiber Box,
i have a Set top box and some computers.
In my Cisco,
i have 8 VLANS which communicate between them.
I would like that my set top box and one computeur plugged in my fiber box
can communicate with the cisco's VLANS.
Network of fiber Box : 192.168.1.0
@ip set top box : 192.168.1.11
@ip computeur : 192.168.1.100
@ ip wan1 : 192.168.1.254
@ip vlan1,2,3,4,5,6,7,8 : 192.168.2.254, 192.168.3.254 etc..... except vlan 6 : 10.1.1.254
Here my Cisco configuration
service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname routeur-cisco1811 ! boot-start-marker boot-end-marker ! logging message-counter syslog enable secret XXXXXXX/ ! aaa new-model ! ! aaa authentication login default local ! ! aaa session-id common ! ! dot11 syslog ip source-route ! ! ip dhcp excluded-address 192.168.3.1 ip dhcp excluded-address 192.168.3.2 192.168.3.99 ip dhcp excluded-address 192.168.3.200 192.168.3.252 ip dhcp excluded-address 192.168.3.254 ip dhcp excluded-address 192.168.3.253 ! ip dhcp pool CASA_LAN network 192.168.3.0 255.255.255.0 dns-server 8.8.8.8 default-router 192.168.3.254 ! ! ip cef no ip domain lookup ip domain name domoticity.com ip name-server 8.8.8.8 ip name-server 8.8.4.4 no ipv6 cef ! multilink bundle-name authenticated ! ! ! username domoticity privilege 15 secret 5 XXXXXXXXX ! ! ! archive log config hidekeys ! ! crypto key generate rsa modulus 1024 ! ip ssh time-out 60 ip ssh logging events ip ssh version 2 ! track 1 ip sla 1 reachability ! track 2 ip sla 2 reachability ! track 3 list boolean and object 1 object 2 ! ! ! interface FastEthernet0 description Acces principal FTTH ip address 192.168.1.254 255.255.255.0 ip nat outside ip virtual-reassembly duplex auto speed auto no shutdown ! interface FastEthernet1 description Acces secour 3/4G ip address 10.0.0.254 255.255.255.0 ip nat outside ip virtual-reassembly duplex auto speed auto no shutdown ! interface FastEthernet2 switchport access vlan 2 no shutdown ! interface FastEthernet3 switchport access vlan 3 no shutdown ! interface FastEthernet4 switchport access vlan 4 no shutdown ! interface FastEthernet5 switchport access vlan 5 no shutdown ! interface FastEthernet6 switchport access vlan 6 no shutdown ! interface FastEthernet7 switchport access vlan 7 no shutdown ! interface FastEthernet8 switchport access vlan 8 no shutdown ! interface Vlan1 no ip address ! interface Vlan2 description domoticity ip address 192.168.2.254 255.255.255.0 ip nat inside ip virtual-reassembly no shutdown ! interface Vlan3 description casa and multimedia ip address 192.168.3.254 255.255.255.0 ip nat inside ip virtual-reassembly no shutdown ! interface Vlan4 description stock and print ip address 192.168.4.254 255.255.255.0 ip nat inside ip virtual-reassembly no shutdown ! interface Vlan5 description domotique and camera ip address 192.168.5.254 255.255.255.0 ip nat inside ip virtual-reassembly no shutdown ! interface Vlan6 description tower control ip address 10.1.1.254 255.255.255.0 ip nat inside ip virtual-reassembly no shutdown ! interface Vlan7 description Orange travail ip address 192.168.7.254 255.255.255.0 ip nat inside ip virtual-reassembly no shutdown ! interface Vlan8 description Phone ip address 192.168.8.254 255.255.255.0 ip nat inside ip virtual-reassembly no shutdown ! ! interface Async1 no ip address encapsulation slip ! ip forward-protocol nd ip route 0.0.0.0 0.0.0.0 192.168.1.1 track 3 ip route 0.0.0.0 0.0.0.0 10.0.0.1 10 no ip http server no ip http secure-server ! ! ip nat inside source route-map BACKUP_ISP interface FastEthernet1 overload ip nat inside source route-map MAIN_ISP interface FastEthernet0 overload ! ip sla 1 icmp-echo 192.168.1.1 source-ip 192.168.1.254 ip sla schedule 1 life forever start-time now access-list 100 permit ip 192.168.2.0 0.0.0.255 any access-list 100 permit ip 192.168.3.0 0.0.0.255 any access-list 100 permit ip 192.168.4.0 0.0.0.255 any access-list 100 permit ip 192.168.5.0 0.0.0.255 any access-list 100 permit ip 192.168.8.0 0.0.0.255 any access-list 100 permit ip 192.168.7.0 0.0.0.255 any access-list 100 permit ip 10.1.1.0 0.0.0.255 any! ! ! ! route-map BACKUP_ISP permit 10 match ip address 100 match interface FastEthernet1 ! route-map MAIN_ISP permit 10 match ip address 100 match interface FastEthernet0 ! ! ! control-plane ! banner login ^C Acces restreint, avec identification !!!!^C banner motd ^C @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@ @@ @@ @@ @@ ROUTEUR CISCO @@ @@ @@ @@ @@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @@ @@ @@ @@ @@ Casa @@ @@ @@ @@ & @@ @@ @@ @@ Domoticity @@ @@ @@ @@ @@ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @: domoticity@gmail.com ^C ! line con 0 line 1 modem InOut stopbits 1 speed 115200 flowcontrol hardware line aux 0 line vty 0 4 transport input ssh line vty 5 15 transport input ssh ! event manager applet CLEAR_NAT_DOWN event track 3 state down action 1.0 cli command "enable" action 2.0 cli command "clear ip nat translations forced" event manager applet CLEAR_NAT_UP event track 3 state up action 1.0 cli command "enable" action 2.0 cli command "clear ip nat translations forced" ! ! ! ! event manager applet get-my-ip event track 2 state down action 1.0 cli command "enable" action 2.0 cli command "ping ip domoticity.ddns.net repeat 1" action 3.0 regexp "Echoes to ([0-9.]+)" $_cli_result match ip action 4.0 puts "My IP is $ip" action 5.0 cli command "config t" action 6.0 cli command "ip route $ip 255.255.255.255 192.168.1.1" action 6.1 cli command "no ip sla 2" action 7.0 cli command "ip sla 2" action 8.0 cli command "icmp-echo $ip source-ip 192.168.1.254" action 9.0 cli command "ip sla schedule 2 life forever start-time now" ! ! ! end
I have tried to put :
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
but i can't ping my vlans.
Solved! Go to Solution.
12-02-2017 12:14 PM
Hello
Your trying to add a nat outside subnet to be NATted, It wont work.
res
Paul
12-02-2017 11:16 AM
do the devices with IP addresses 192.168.1.11 and 192.168.1.100 have 192.168.1.254 configured as their default gateway ? Can they ping that address ?
12-02-2017 12:14 PM
Hello
res
Paul
12-03-2017 01:20 AM
I have (sort of, since I don't know what exactly the Fiber Box does), but it seems to me that basically the 192.168.1.0/24 network is simply a connected network ?
Try and change your access list to the one below. This basically excludes all traffic to the Fiber Box network to be NATted:
access-list 100 deny ip 192.168.2.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 100 deny ip 192.168.3.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 100 deny ip 192.168.4.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 100 deny ip 192.168.5.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 100 deny ip 192.168.7.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 100 deny ip 192.168.8.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 100 deny ip 10.1.1.0 0.0.0.255 192.168.1.0 0.0.0.255
12-04-2017 01:14 PM
12-04-2017 02:19 PM
the idea was actually to exclude the network from being NATted at all. What exactly does this fiber box do ? What type/brand is it ? Is the IP address of the router the default gateway for the clients connected to the fiber box ?
