Cisco 1812 Router
publigroupe
I just had a bonded T1 (3Meg) installed. Does the 1812 support this type of connection? Do i need a CSU/DSU between the T1 and the router. Finally, should i be using an RJ45 or RJ48 connector?
Laurent Aubert
1812 doesn't support serial connection.
You need a 28xx router.
Laurent.
Hi Laurent,
Thanks for your response.
