cisco 1841 router LAN port hanging issues on MPLS
sandeshkolhe
Dear All,
I have 3 locations connected with MPLS connectivity … 2 mbps , 2 mbps branches and 4 mbps and HO
HO, I have Cisco 1841 router
Last few days I am facing problem that Cisco 1841 router’s Lan port suddenly stop working and connectivity get disconnected.
In this stage branch offices can reach up to CISCO 1841 WAN port.
( I have changed 2 different router assuming router problem but issues remain same, Hence No hardware problem )
Please help me if anyone seen this problem …thanks
7 Replies 7
sandeshkolhe
does anyone have solution for the issue ??
I guess the links are on ethernet try using IP SLA command.
Also check the port configuration @ provider end.
Ranjit
Thanks Ranjit, but can you please explain in some detail ...thanks
I'm also having same problem here. after few days router LAN is hanging. after restarting router works fine for few days. I have enabled logs too. but there is nothing.   if anyone can help much appreciated.
thank you
Kindly provide the output of "show proc cpu sorted" & "show proc memory sorted" when you see the issue again.
Thanks & Regards,
Vignesh R P
Are your monitoring router in any monitoring software did u see cpu usage.  also enabling netflow on router to monitor traffic when this happens.
Jawad
Jawad
I'm sorry if I'm doing wrong thing by posting my router details and if it is please let me know.
CPU utilization for five seconds: 2%/3%; one minute: 1%; five minutes: 0%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
   3        1172       291       4027  1.80%  1.27%  0.34%   2 Virtual Exec
  25      261068    168736       1547  0.98%  0.44%  0.33%   0 IP Input
   2          24     13793          1  0.00%  0.00%  0.00%   0 Load Meter
   4       48800      8180       5965  0.00%  0.07%  0.06%   0 Check heaps
   5           4        15        266  0.00%  0.00%  0.00%   0 Pool Manager
   6           0         1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
   7           8         2       4000  0.00%  0.00%  0.00%   0 Timers
   8           0         2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
   9           0         2          0  0.00%  0.00%  0.00%   0 AAA high-capacit
  10         256      1281        199  0.00%  0.00%  0.00%   0 ARP Input
  11          12         3       4000  0.00%  0.00%  0.00%   0 DDR Timers
  12          12         2       6000  0.00%  0.00%  0.00%   0 Entity MIB API
  13           0         1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  14         312     68889          4  0.00%  0.00%  0.00%   0 GraphIt
  15           0         1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  16        2012     79726         25  0.00%  0.00%  0.00%   0 Net Background
  17           4        11        363  0.00%  0.00%  0.00%   0 Logger
  18         516     68886          7  0.00%  0.00%  0.00%   0 TTY Background
  19        1152     68892         16  0.00%  0.00%  0.00%   0 Per-Second Jobs
  20         472    181251          2  0.00%  0.00%  0.00%   0 LED Timers
  21           4         2       2000  0.00%  0.00%  0.00%   0 AAA Server
  22           0         1          0  0.00%  0.00%  0.00%   0 AAA ACCT Proc
  23           0         1          0  0.00%  0.00%  0.00%   0 ACCT Periodic Pr
  24           8         2       4000  0.00%  0.00%  0.00%   0 AAA Dictionary R
   1           0         1          0  0.00%  0.00%  0.00%   0 Chunk Manager
  26           0         1          0  0.00%  0.00%  0.00%   0 ICMP event handl
  28           0         2          0  0.00%  0.00%  0.00%   0 PPP Hooks
  29       10100      1156       8737  0.00%  0.00%  0.00%   0 IP Background
  30         128      1153        111  0.00%  0.00%  0.00%   0 IP RIB Update
  31           0         2          0  0.00%  0.00%  0.00%   0 PPP IP Route
  32           0         2          0  0.00%  0.00%  0.00%   0 PPP IPCP
  33          64       438        146  0.00%  0.00%  0.00%   0 TCP Timer
  34          64        19       3368  0.00%  0.00%  0.00%   0 TCP Protocols
  35           0         1          0  0.00%  0.00%  0.00%   0 RARP Input
  36          24         2      12000  0.00%  0.00%  0.00%   0 DHCPD Receive
  37           0         1          0  0.00%  0.00%  0.00%   0 Socket Timers
  38         204        59       3457  0.00%  0.00%  0.00%   0 HTTP CORE
  39         140      1148        121  0.00%  0.00%  0.00%   0 IP Cache Ager
  40           4         2       2000  0.00%  0.00%  0.00%   0 PPP Bind
  41           0         2          0  0.00%  0.00%  0.00%   0 LOCAL AAA
  42           4         2       2000  0.00%  0.00%  0.00%   0 ENABLE AAA
  43           4         2       2000  0.00%  0.00%  0.00%   0 LINE AAA
  44           0         2          0  0.00%  0.00%  0.00%   0 AAA SEND STOP EV
  45        2424      6751        359  0.00%  0.00%  0.00%   0 Net Input
  46          16     13795          1  0.00%  0.00%  0.00%   0 Compute load avg
  47       86044      1171      73479  0.00%  0.08%  0.10%   0 Per-minute Jobs
  48           4       575          6  0.00%  0.00%  0.00%   0 DHCPD Timer
  49        2292     19501        117  0.00%  0.00%  0.00%   0 DHCPD Database
Total: 7786496, Used: 2586432, Free: 5200064
PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process
   0   0     194116      22068    1580028          0          0 *Init*
   0   0    3656700     989960      77452     172528          0 *Dead*
  25   0     109360       9504      39360          0          0 IP Input
  36   0      50608        188      33152          0          0 DHCPD Receive
   3   2      16008       4020      29068       4536          0 Virtual Exec
  38   0      37064      32984      25444          0          0 HTTP CORE
  34   0     206288          0      22864          0          0 TCP Protocols
  16   0      52068          0      21628          0          0 Net Background
  30   0        152          0      21516          0          0 IP RIB Update
  29   0         76          0      21460          0          0 IP Background
  32   0        188        188      21364          0          0 PPP IPCP
  28   0        188        188      21364          0          0 PPP Hooks
  31   0        188        188      21364          0          0 PPP IP Route
  33   0          0      16632      21364          0          0 TCP Timer
  17   0        188        188      21364          0          0 Logger
  19   0          0          0      21364          0          0 Per-Second Jobs
  12   0       2168        520      18916          0          0 Entity MIB API
  10   0        200      58200      17468          0          0 ARP Input
  49   0        188          0      17456          0          0 DHCPD Database
  15   0          0          0      17268          0          0 Critical Bkgnd
  18   0        188        188      17268          0          0 TTY Background
  14   0        188        188      17268          0          0 GraphIt
  20   0        188        188      17268          0          0 LED Timers
  21   0        188        188      17268          0          0 AAA Server
  22   0          0          0      17268          0          0 AAA ACCT Proc
  13   0          0          0      17268          0          0 SERIAL A'detect
  24   0        188        188      17268          0          0 AAA Dictionary R
  11   0        188        188      17268          0          0 DDR Timers
  26   0          0          0      17268          0          0 ICMP event handl
   9   0        188        188      17268          0          0 AAA high-capacit
   8   0        188        188      17268          0          0 Serial Backgroun
   7   0        188        188      17268          0          0 Timers
   6   0          0          0      17268          0          0 AAA_SERVER_DEADT
   5   0          0       2268      17268          0       2412 Pool Manager
   4   0          0          0      17268          0          0 Check heaps
  35   0          0          0      17268          0          0 RARP Input
  42   0        188        188      17268          0          0 ENABLE AAA
   1   0          0          0      17268          0          0 Chunk Manager
  37   0          0          0      17268          0          0 Socket Timers
  43   0        188        188      17268          0          0 LINE AAA
  39   0          0          0      17268          0          0 IP Cache Ager
  40   0        188        188      17268          0          0 PPP Bind
  41   0        188        188      17268          0          0 LOCAL AAA
  44   0        188        188      17268          0          0 AAA SEND STOP EV
  46   0        188        188      17268          0          0 Compute load avg
  47   0          0          0      17268          0          0 Per-minute Jobs
  45   0          0          0      17268          0          0 Net Input
  23   0          0          0      17268          0          0 ACCT Periodic Pr
  48   0          0          0      17268          0          0 DHCPD Timer
   2   0        188        188      13172          0          0 Load Meter
   0   0        224     210204        224          0          0 *Sched*
                                  2585432 Total
sh ver
IOS (tm) C805 Software (C805-Y6-MW), Version 12.2(15)T12,  RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Thu 25-Mar-04 05:37 by cmong
Image text-base: xxxxxxxx, data-base: xxxxxxxxxxxx
ROM: TinyROM version 1.4(1)
fac-int uptime is 19 hours, 14 minutes
System returned to ROM by reload
System image file is "flash:c805-y6-mw.122-15.T12.bin"
Cisco C805  (MPC850) processor (revision 0) with 48468K bytes of virtual memory.
Processor board ID FOC082307K1 (3893625006)
CPU part number 0x2101
Bridging software.
1 Ethernet/IEEE 802.3 interface(s)
1 Serial(sync/async) network interface(s)
8M bytes of physical memory (DRAM)
8K bytes of non-volatile configuration memory
8M bytes of flash on board (4M from flash card)
