12-13-2011 04:20 PM - edited 03-04-2019 02:37 PM
I am configuring a 1841 router for use in small out office. I will use the s0/0/0 for main WAN T1 connection. I then wanted to use the ATM0/1/0 WIC-1-ADSL card as a failover.
I am using weighted static routes for failover. Fe0/0 is LAN interface.
When I go into SDM and look at the ATM interface it says this configuration is unsupported?
1. Can't I just get a DSL modem and connect it to fe0/1 and not use ATM WIC and use below for failover?
2. If I have to use ATM WIC what needs to be configured for it to work with Att aDSL?
interface ATM0/1/0
no ip address
ip nat outside
ip virtual-reassembly
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
ip route 0.0.0.0 0.0.0.0 Serial0/0/0
ip route 0.0.0.0 0.0.0.0 ATM0/1/0 100
ip nat inside source route-map outside_nat interface Serial0/0/0 overload
ip nat inside source route-map outside_nat_failover interface ATM0/1/0
route-map outside_nat_failover permit 1
match ip address 100
route-map outside_nat permit 1
Extended IP access list 100
10 permit ip 192.168.16.0 0.0.0.255 any
20 permit ip host 192.168.17.2 any
30 permit ip 192.168.18.0 0.0.0.255 any
40 permit ip 192.168.20.0 0.0.0.255 any
12-14-2011 01:05 AM
Hi David,
Just one suggestion about the config.
ip route 0.0.0.0 0.0.0.0 Serial0/0/0 -> this router will remain in routing table, until the serial interface goes down.
Typically, your serial port is connected to a Telco device (CSU/DSU). This means that if there is a network failure (behind the telco device), your serial port will still be up/up, even if there is no connectivity.
You may use an IP SLA to track the reachability of a remote IP, and add the track to the route command.
Regarding the DSL link, ATM is just the lower layer, you shouldn't configure L3 there. You need to add a dialer interface over it, and use the dialer in the NAT/route commands.
Example of configuration:
http://www.cisco.com/en/US/tech/tk175/tk15/technologies_configuration_example09186a008071a60e.shtml
Hope this helps
Marco
