01-12-2016 06:33 AM - editado 03-05-2019 03:06 AM
hello , I have cisco 1841 router with IOS c1841-adventerprisek9-mz.151-3.T2.bin
I have problem with defaul Vlan , it doesn't exist, can you help me for this case?
this is output - sh ip int brief
CCNP#sh ip int brief
Interface IP-Address OK? Method Status Prot
ocol
FastEthernet0/0 192.168.2.200 YES NVRAM up up
FastEthernet0/1 unassigned YES NVRAM administratively down down
Serial0/0/0 unassigned YES NVRAM administratively down down
el 01-12-2016 07:55 AM
Hi there,
if you want to enable VLAN tagging on the interfaces you will need to configure them as sub-interfaces. Eg; If you wanted to create a router interface on fa0/0 in VLAN10 and tag those packets, try this configuration:
int fastethernet0/0.10
encapsulation dot1q 10
ip address 192.168.10.254 255.255.255.0
no shut
cheers,
Seb.
el 01-12-2016 08:31 AM
No, I want make managment ip address woth vlan 1 but there is no vlan . When i type command " int vlan 1" , error is appears.
el 01-12-2016 12:08 PM
The 1841 is a router and not a switch. It has routed ports and no vlan-interfaces (unless you insert a switch-module into one of the slots).
el 01-12-2016 01:40 PM
Ah OK, try this:
ip vrf management
description management VRF
int fa0/0
no shut
ip vrf forwarding management
ip address 192.168.2.200 255.255.255.0
no shut
You need to create a sub-interface to get IOS to tag VLAN1 on fa0/0. You can confirm this:
r3#sh int fa0/0
FastEthernet0/0 is up, line protocol is down
Hardware is Gt96k FE, address is 001e.4a8c.1726 (bia 001e.4a8c.1726)
Internet address is 192.168.1.254/24
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set
Keepalive set (10 sec)
If you don't want to create VLAN10, then explicitly create the VLAN1 sub-interface:
no shut
r3#sh int fa0/0.1
FastEthernet0/0.1 is up, line protocol is down
cheers,
Seb.
Please rate helpful posts :)
el 01-12-2016 11:08 AM
Moving discussion to the Network Infrastructure>WAN,Routing community for greater visibility
Descubra y salve sus notas favoritas. Vuelva a encontrar las respuestas de los expertos, guías paso a paso, temas recientes y mucho más.
¿Es nuevo por aquí? Empiece con estos tips. Cómo usar la comunidad Guía para nuevos miembros
