09-16-2015 08:43 AM - edited 03-05-2019 02:19 AM
Hello
I cannot seem to get our 1921 with a 4g EHWIC card added.
We want to use ADSL as a main connection and 4G as a backup. I've struggled so much with the 4G EHWIC that I deleted the entire ADSL config just to try and get cellular working and it does not work. The provider is EE. It can see the sim card but nothing seems to happen. I don't get any (useful) debug output either.
Building configuration... Current configuration : 4970 bytes ! ! Last configuration change at 14:39:54 UTC Wed Sep 16 2015 by truebyte version 15.2 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption service internal ! hostname R1 ! boot-start-marker boot-end-marker ! ! ! aaa new-model ! ! aaa authentication login default local aaa authorization console aaa authorization exec default local ! ! ! ! ! aaa session-id common ! ip cef ! ! ! ! ! ! ! ! ! ! ip inspect WAAS flush-timeout 10 no ipv6 cef ! multilink bundle-name authenticated ! chat-script lte "" "AT!CALL" TIMEOUT 60 "OK" ! ! ! ! ! username ** privilege 15 secret 5 *** ! redundancy notification-timer 60000 ! ! ! ! ! controller Cellular 0/1 ! controller VDSL 0/0/0 ! ! class-map type inspect match-any ZBF-CLASS match access-group name INSIDE_TO_OUTSIDE match protocol http match protocol https match protocol icmp match protocol dns match protocol smtp match protocol ssh match protocol ftp match protocol ftps match protocol imap match protocol ica match protocol telnet ! policy-map type inspect ZBF-POLICY class type inspect ZBF-CLASS inspect class class-default drop ! zone security inside zone security outside zone-pair security INSIDE_TO_OUTSIDE source inside destination outside service-policy type inspect ZBF-POLICY ! ! ! ! ! ! ! ! ! interface Embedded-Service-Engine0/0 no ip address shutdown ! interface GigabitEthernet0/0 description LAN PORT ip address 10.110.10.1 255.255.255.0 ip nat inside ip virtual-reassembly in zone-member security inside shutdown duplex auto speed auto ! interface GigabitEthernet0/1 description FIBRE PORT no ip address shutdown duplex auto speed auto ! interface ATM0/0/0 no ip address shutdown no atm ilmi-keepalive ! interface Ethernet0/0/0 no ip address shutdown ! interface Cellular0/1/0 ip address negotiated ip nat outside ip virtual-reassembly in encapsulation slip dialer in-band dialer idle-timeout 60 dialer string lte dialer-group 1 async mode interactive ! interface Dialer0 no ip address ! ip local pool VPN_POOL 10.7.99.10 10.7.99.30 ip forward-protocol nd ! ip http server ip http authentication local ip http secure-server ! ip nat inside source list NAT interface Dialer0 overload ip nat inside source static tcp 10.110.10.40 25 81.86.54.139 25 extendable ip nat inside source static tcp 10.110.10.40 443 81.86.54.139 443 extendable ip route 0.0.0.0 0.0.0.0 Cellular0/1/0 ! ip access-list extended INSIDE_TO_OUTSIDE permit ip 10.110.10.0 0.0.0.255 any ip access-list extended LAN ip access-list extended NAT remark NO NAT STATEMENT deny ip 10.110.10.0 0.0.0.255 10.7.99.0 0.0.0.255 remark NAT THE REST permit ip 10.110.10.0 0.0.0.255 any ! ! ! ! ! ! control-plane ! ! ! line con 0 transport output none line aux 0 no exec transport input all transport output all line 2 no activation-character no exec transport preferred none transport output all stopbits 1 line 0/1/0 exec-timeout 0 0 script dialer lte modem InOut no exec transport preferred none transport input all transport output none line vty 0 4 transport input telnet ssh line vty 5 15 transport input telnet ssh ! scheduler allocate 20000 1000 ! end
R1# show interfaces cellular 0/1/0 Cellular0/1/0 is up (spoofing), line protocol is up (spoofing) Hardware is 4G WWAN EHWIC - Global Multimode LTE/DC-HSPA+/HSPA+/HSPA/UMTS/EDGE/GPRS Internet address will be assigned dynamically by the network MTU 1500 bytes, BW 9 Kbit/sec, DLY 100000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation SLIP, loopback not set Keepalive not supported Last input never, output never, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/10 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 0 packets input, 0 bytes, 0 no buffer Received 0 broadcasts (0 IP multicasts) 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 0 packets output, 0 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 unknown protocol drops 0 output buffer failures, 0 output buffers swapped out 0 carrier transitions DCD=down DSR=down DTR=up RTS=up CTS=up
R1#show cellular 0/1/0 all Hardware Information ==================== Modem Firmware Version = SWI9200X_03.05.19.04 Modem Firmware built = 2012/09/17 17:57:14 Hardware Version = 10 International Mobile Subscriber Identity (IMSI) = 234304113458925 International Mobile Equipment Identity (IMEI) = 359470040026454 Integrated Circuit Card ID (ICCID) = 8944303081950296845 Mobile Subscriber International Subscriber IDentity Number (MSISDN) = 447719598138 Profile Information ==================== Profile 1 = INACTIVE* -------- PDP Type = IPv4 Access Point Name (APN) = everywhere Authentication = PAP Username: eesecure Password: secure * - Default profile Data Connection Information =========================== Data Transmitted = 0 bytes, Received = 0 bytes Profile 1, Packet Session Status = INACTIVE Inactivity Reason = Unknown Profile 2, Packet Session Status = INACTIVE Inactivity Reason = Unknown Profile 3, Packet Session Status = INACTIVE Inactivity Reason = Unknown Profile 4, Packet Session Status = INACTIVE Inactivity Reason = Unknown Profile 5, Packet Session Status = INACTIVE Inactivity Reason = Unknown Profile 6, Packet Session Status = INACTIVE Inactivity Reason = Unknown Profile 7, Packet Session Status = INACTIVE Inactivity Reason = Unknown Profile 8, Packet Session Status = INACTIVE Inactivity Reason = Unknown Profile 9, Packet Session Status = INACTIVE Inactivity Reason = Unknown Profile 10, Packet Session Status = INACTIVE Inactivity Reason = Unknown Profile 11, Packet Session Status = INACTIVE Inactivity Reason = Unknown Profile 12, Packet Session Status = INACTIVE Inactivity Reason = Unknown Profile 13, Packet Session Status = INACTIVE Inactivity Reason = Unknown Profile 14, Packet Session Status = INACTIVE Inactivity Reason = Unknown Profile 15, Packet Session Status = INACTIVE Inactivity Reason = Unknown Profile 16, Packet Session Status = INACTIVE Inactivity Reason = Unknown Network Information =================== Current Service Status = Normal Current Service = Packet switched Current Roaming Status = Home Network Selection Mode = Automatic Mobile Country Code (MCC) = 234 Mobile Network Code (MNC) = 30 Packet switch domain(PS) state = Attached Registration(EMM) state = Registered Radio Information ================= Radio power mode = ON Current RSSI = -75 dBm LTE Technology Preference = AUTO LTE Technology Selected = LTE Modem Security Information ========================== Card Holder Verification (CHV1) = Disabled SIM Status = OK SIM User Operation Required = None Number of CHV1 Retries remaining = 3 Error Information ================= This command is not supported on 4G modems. Modem Crashdump Information =========================== Modem crashdump logging: off
R1#ping 8.8.8.8 Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds: ..... Success rate is 0 percent (0/5)
Anyone got any idea what is going on or what I can try next?
Thanks in advance.
Mark
