11-29-2012 04:26 AM - edited 03-04-2019 06:16 PM
I am trying to get the Cisco 1921 to route between 2 LANs. I can ping from the router itself, but cannot ping across either, is there something I am doing wrong here:
version 15.1
!no aaa new-model
!no ipv6 cef
ip source-route
ip cef
!ip dhcp excluded-address 192.168.1.1
ip dhcp excluded-address 192.168.5.1
!ip dhcp pool vlan5
network 192.168.5.0 255.255.255.0
dns-server 192.168.5.1
default-router 192.168.5.1
lease 7
ip dhcp pool native1
network 192.168.1.0 255.255.255.0
dns-server 192.168.1.1
default-router 192.168.1.1
lease 7
!interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 128.65.102.102 255.255.0.0
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.1
encapsulation dot1Q 1 native
ip nat inside
interface GigabitEthernet0/1.5
encapsulation dot1Q 5
ip address 192.168.5.1 255.255.255.0
no ip redirects
no ip unreachables
ip flow ingress
ip nat inside
!ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 128.65.101.204
11-29-2012 04:48 AM
Check PC's have firewall disabled.
11-29-2012 06:06 AM
Yep, these have been disabled. It's not the PCs though, I can't even ping the gateway (128.65.101.204) on the WAN side from behind the router.
11-29-2012 06:25 AM
Hi Robert,
Just a random check is the switch port coming from router has been trunked.
Thanveer
"Everybody is genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is a stupid."
11-29-2012 06:29 AM
can you also post switch config?
11-29-2012 06:34 AM
Maybe has not been incoded, but you also need a nat command in global config.
11-29-2012 07:52 AM
Muhammed,
The router doesn;t have switchports, so not sure how I can do that? It only has the 2 gigabit ports built-in and as listed above.
Paolo,
What NAT command would I need? Would this stop traffic even going from behind the NAT to infront of it?
Edit: nevermind, I've managed to get it, I needed NAT and access list commands in there.
Thanks to both.
11-29-2012 09:22 AM
How would I shape traffic in both directions on the VLANs above to the 0/0 interface.
So for instance give VLAN 1 20Mbps and VLAN 5 30Mbps?
I have added the following policy:
class-map match-any CLASS_EtherFlow_Shaping
match any
policy-map POLICY_EtherFlow_Shaping
class CLASS_EtherFlow_Shaping
shape average 29000000
and attached this to VLAN 5, but this way I can only manage traffic coming inbound. How would I do this to cover outbound traffic as well?
11-29-2012 09:33 AM
Actually the shaping command afftect outbound traffic, that is, leaving the interface.
To limit traffic entering an interface, apply shaping to the other interface where it leaves the router.
11-29-2012 09:38 AM
Ok, yes that makes sense, but if I only have VLANs on one interface, how do I limit it the other direction? I would only be able to limit traffic for all the VLANs then and not individually?
11-29-2012 09:42 AM
You would use ACLs in class-map to define what IPs are limited and what are not.
Please remember to rate useful posts clicking on the stars below.
