11-19-2014 11:04 PM - edited 03-05-2019 12:12 AM
Good day,
I would like to confirm if I can use a wic-2T card on a Cisco 1921 router? I have read different articles on this and they are saying different things.
Can I run crypto on the router? I want to use it to terminate an IPSec Tunnel.
Nelson
Solved! Go to Solution.
11-19-2014 11:29 PM
I think you can use HWIC-2T supported in 12.4(15)T onwards with IP Base license. The WIC-2T is no longer supported on newer ISRs.
For IPSec and crypto, firstly a K9 image required, also I believe you will need a Security License
http://www.cisco.com/c/dam/en/us/products/collateral/routers/1900-series-integrated-services-routers-isr/aag_c07_563807.pdf
hth
Bilal - CCIE #45032
11-19-2014 11:29 PM
hth
Bilal - CCIE #45032
11-21-2014 02:18 AM
Thanks a lot Bilal, I also have a Security License, and all is looking good.
