cisco 1921
Luongcun11
I have a cisco 1921 router and I cannot get into the device any more because of the defaulted one-time cisco username and password.
How can I reset the device to factory and set my own username? Also, where can I download/use the cisco configuration professional (CP)?
acampbell
Use the link below to reset the password on your router.
Once you are back on you can default the router with
YOURROUTER#erase start
YOURROUTER#reload
http://www.cisco.com/c/en/us/support/docs/routers/3800-series-integrated-services-routers/112058-c1900-pwd-rec-00.html
Alex
Regards, Alex. Please rate useful posts.
