Cisco 1941 NAT Loss
I try to configure PAT on the Cisco1941 when using source inside (LAN), I found loss 7%. However, from source outside (WAN) have no loss. The CPU is just 1%. How should I do? Is there any NAT limitation on Cisco1941?
Thank you very much.
what do you mean with 7% loss ? Are you losing PING (ICMP) packets ? Post the running configuration of your 1941 router.
Hello
Not enough information to understand your issue?
What wan connection do you have (mpls-lre-ppp etc..)
What routing protocols if any are you using
What NAT are you using ( domain (inside/outside) or domainless
Are you implementing any QOS?
Have you tired a test from a host within your network instead of the rtrs lan interface?
Kind Regards
Paul
Configuration:
Spoiler
interface GigabitEthernet0/0
 ip address x.170.112.222 255.255.255.252
 ip load-sharing per-packet
 ip nat outside
interface GigabitEthernet0/1
 ip address x.170.112.234 255.255.255.252
 ip nat outside
interface Vlan100
 ip address 192.168.100.100 255.255.255.0
 ip flow ingress
 ip nat inside
ip nat inside source list 10 interface GigabitEthernet0/0 overload
ip nat inside source list 20 interface GigabitEthernet0/1 overload
access-list 10 permit 192.168.100.0 0.0.0.255
access-list 20 permit 192.168.100.0 0.0.0.255
MPLS L2VPN to the Service Provider
Just default route to the Internet
Can see in the configuration
Nope
Same result
is there a specific reason for the 'per-packet' load sharing ? That alone could be your issue. Change that to the default 'per-destination' load balancing.
Also, if you use static routes, are we talking about two static default routes ? Post the output of 'show ip route'.
