Cisco 1941w ethrnet switch
Hello!
I have 1941W for my personal usu and LAB.
From the post
https://community.cisco.com/t5/switching/1941w-expansion-slots/m-p/3089729#M387605
I know EHWIC-D-8ESG-P (8 port) EHWIC-D-4ESG (4 port) are supported.
   (BTW 10/100 Hwic are not)
My primary question is:
If I'll buy EHWIC-D-8ESG-P now but still use NON -PoE power sup. will I be able to use EHWIC-D-8ESG-P just as data switch without PoE? My be will buy PWR-1941-POE later.
Aso do somone know can I convert EHWIC-D-8ESG to EHWIC-D-8ESG-P with IPLM-8 or somthing like that?
Thanks for help!
Georg Pauwen
VIP Master VIP Master
VIP Master
--> If I'll buy EHWIC-D-8ESG-P now but still use NON -PoE power sup. will I be able to use EHWIC-D-8ESG-P just as data switch without PoE? My be will buy PWR-1941-POE later.
Without the PWR-1941-POE=, the ports on the module will just function as normal ports. I think without the power supply, you don't even have the 'power inline' options available.
Georg Pauwen
VIP Master
Recognize Your Peers
