588
williamtwomey
Beginner
Cisco 2600 ADSL WIC Cannot access remotely
I have a Cisco 2600 with an ADSL WIC installed.
I get an IP from my ISP, NAT works, etc. but I cannot SSH in remotely (even with all access lists removed from my Dialer interface).
Wondering if I'm missing something obvious.
Is there anything glaring wrong with my config that would prevent incomming traffic? I can ssh into the device locally, so SSH is indeed enabled.
Cisco 2621XM
c2600-advipservicesk9-mz.124-19.bin"
version 12.4
service password-encryption
hostname SL2600
boot-start-marker
boot system flash:c2600-advipservicesk9-mz.124-19.bin
boot-end-marker
enable secret <SNIP>
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
no ip dhcp use vrf connected
ip name-server 4.2.2.2
ip inspect name firewall udp
ip inspect name firewall tcp
ip inspect name firewall http java-list 10
ip inspect name firewall https
ip inspect name firewall ftp
ip inspect name firewall icmp
ip inspect name firewall dns
ip inspect name firewall ntp
ip inspect name firewall tftp
ip inspect name firewall realaudio
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
username admin privilege 15 <SNIP>
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 5
bridge irb
interface FastEthernet0/0
description "Switch Management"
ip address 192.168.1.2 255.255.255.0
ip virtual-reassembly
ip route-cache flow
ip tcp adjust-mss 1452
duplex auto
speed auto
hold-queue 100 out
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address 10.10.0.254 255.255.0.0
ip nat inside
interface ATM0/1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no atm ilmi-keepalive
bundle-enable
dsl operating-mode auto
hold-queue 224 in
interface ATM0/1.1 point-to-point
description $FW_OUTSIDE$$ES_WAN$
pvc 0/35
  pppoe-client dial-pool-number 2
interface Dialer1
description WAN
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 2
dialer-group 2
no cdp enable
ppp authentication chap pap callin
ppp chap hostname <SNIP>
ppp chap password 7 <SNIP>
ppp pap sent-username <SNIP>
ip route 0.0.0.0 0.0.0.0 Dialer1 permanent
ip access-list extended INPUT_ACL
permit ip any any
ip access-list extended NAT_ACL
permit ip any any
line con 0
exec-timeout 120 0
logging synchronous
login local
transport output telnet ssh
stopbits 1
line aux 0
login local
line vty 0 4
privilege level 15
password 7 144F37232E0778253662
login
length 0
transport input ssh
1 ACCEPTED SOLUTION
paolo bevilacqua
Hall of Fame Master
conf t
no  permit ip any any
permit ip 10.10.0.0 0.255.255.255
3 REPLIES 3
paolo bevilacqua
Hall of Fame Master
conf t
Haha thanks!
Thank you for the nice rating and good luck!
