03-31-2008 10:10 PM - edited 03-03-2019 09:21 PM
I got a terminal server with 2 octal cables attached to it. each octal cable has 8 RJ45 plugs. I installed a patch panel today and plug them into the back of the patch panel. I'll use the front panel as Out of Band ports.
However I can't access other device from my terminal server. I used rollover cable between the patch panel and my device. I was thinking maybe the octal cable is already rolled over. here are my partial output.
line 33 48
session-timeout 5
exec-timeout 5 0
flush-at-activation
no exec
transport input all
transport output none
escape-character BREAK
telnet ip-on-break
stopbits 1
flowcontrol hardware
AS05#sh line
Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
0 CTY - - - - - 0 0 0/0 -
* 33 TTY 9600/9600 - - - - - 1 0 0/0 -
* 34 TTY 9600/9600 - - - - - 1 0 0/0 -
35 TTY 9600/9600 - - - - - 0 0 0/0 -
36 TTY 9600/9600 - - - - - 0 0 0/0 -
37 TTY 9600/9600 - - - - - 0 0 0/0 -
38 TTY 9600/9600 - - - - - 0 0 0/0 -
39 TTY 9600/9600 - - - - - 0 0 0/0 -
40 TTY 9600/9600 - - - - - 0 0 0/0 -
41 TTY 9600/9600 - - - - - 0 0 0/0 -
42 TTY 9600/9600 - - - - - 0 0 0/0 -
43 TTY 9600/9600 - - - - - 0 0 0/0 -
44 TTY 9600/9600 - - - - - 0 0 0/0 -
45 TTY 9600/9600 - - - - - 0 0 0/0 -
46 TTY 9600/9600 - - - - - 0 0 0/0 -
47 TTY 9600/9600 - - - - - 0 0 0/0 -
* 48 TTY 9600/9600 - - - - - 1 0 0/0 -
65 AUX 9600/9600 - - - - - 2 0 0/0 -
* 66 VTY - - - - - 7 0 0/0 -
67 VTY - - - - - 4 0 0/0 -
68 VTY - - - - - 0 0 0/0 -
69 VTY - - - - - 0 0 0/0 -
70 VTY - - - - - 0 0 0/0 -
Line(s) not in async mode -or- with no hardware support:
1-32, 49-64
Solved! Go to Solution.
04-01-2008 12:09 AM
The octal cables are already rolled over. you need to use a normal patch cable fron ur patch panel to the device
also configure
ip host R1 2033
ip host R2 2034
ip host R3 2035
ip host R4 2036
ip host R5 2037
ip host R6 2038
for all the lines
Narayan
04-01-2008 12:09 AM
also configure
ip host R1 2033
ip host R2 2034
ip host R3 2035
ip host R4 2036
ip host R5 2037
ip host R6 2038
for all the lines
Narayan
