CISCO 2611MX with TWC Ethernet Handoff.
joecordova
Hello everyone,
We are switching over to TWC Ethernet handoff from T1 circuit at our school. We are using a Cisco Router 2611mx with two f0/0 - f0/1 interface ports.
Our NAT is being done on our Cisco PIX506 and  is on the inside of our router. The ISP has given us 13 public address. My question is can we still keep our current setup with this new Ethernet handoff circuit?
I have configured the following on our router that is connected to TWC switch.
CISCO 2611MX ROUTER:
config - t : interface f0/0 ip address 27.112.xx.82 255.255.255.2xx
config - t : no shutdown
outside port to ISP...
With this is set up on the outside port I can't ping anything for whatever reason.
tried ping 8.8.8.8 no response... however I can ping the TWC device with is 27.112.xx.81.
I am missing something? The ISP tech plug-in his laptop with the same IP address was able to connect internet.
TWC Ethenet Port: 27.122.xx.81
CISCO 2611MX ROUTER "outside" Port: 27.112.xx.82
CISCO PIX506 "outside" Port: 27.112.xx.66
CISCO PIX506 "inside" Port 192.168.10.1
Any help would be greatly appreciated.
cralvara
Level 6
Level 6
Hello Joe,
I hope that you are doing great.
I would suggest you to contact our Technical Assistance Center (TAC). This is the dedicated group highly trained with troubleshooting, and other Post- sales related concerns.
You may contact them via email at tac@cisco.com. Also, you can open a case for this issue at http://tools.cisco.com/ServiceRequestTool/create/launch.do or call them directly, to get the numbers for specific country go to: http://www.cisco.com/en/US/support/tsd_cisco_worldwide_contacts.html
Hopefully they will help.
Best Regards.
Cristina Alvarado
Cisco Virtual Engineering- Partner Help.
